97 XK8 ECU Repaired and Replaced
Old May 18, 2021 | 11:26 PM
NYN8IVE's Avatar
Default 97 XK8 ECU Repaired and Replaced
Shop left me a voicemail that I can pick my XK8 up which seems to indicate the repair removed the misfiring fault codes for 2 Cylinders on each bank.
Fingers crossed!
My question is what needs to be done regarding the ECU resetting? It’s critical because my vehicle needs to be retested at the smog inspection station. It failed due to battery replacement last month which started this odyssey.
Old May 19, 2021 | 03:23 AM
It will likely now show only P1000 meaning DTC's have been cleared and all engine management OBD diagnostic monitor drive cycles HAVE NOT BEEN COMPLETED.
Although normal driving will eventually complete the tests, this can take a very long time and many thousands of miles You will need to use "Drive Cycles" (see attached) to do this in the shortest possible time and show P1111.
Old May 19, 2021 | 08:26 AM
CA Jag's Avatar
Agree drive cycles. Did it 3x and got P1111. Only challenge was finding someplace to speed up/slow down w/o causing someone to curse the old guy in a Jag.
Old May 19, 2021 | 09:35 AM
Jon89's Avatar
Long and typically empty stretches of rural roads are best for doing these drive cycles. Being familiar with the time of day (or night) when these roads are most empty always helps....
Old May 19, 2021 | 10:26 AM
NYN8IVE's Avatar
Thanks everyone I will try the cycles on the weekend, just a little apprehensive about getting stuck. I’m down to 1 remaining Tow from AAA but more concerned about safety.
Old May 25, 2021 | 08:55 PM
NYN8IVE's Avatar
Default ECU Repair Update
I’ve been doing short trips since my vehicle was returned to me. No stalling issues or rough idle and fires up instantly. The only issue is when accelerating it occasionally seems to be pushing back or exhibits lack of power. Today I drove quite a bit in 2nd so I could get the revs up to 4K for a period of time. My question? Is this behavior indicative of the ECU needing to reset itself while driving the cycles or something else? Thanks in advance.
Old May 26, 2021 | 02:48 AM
JagV8's Avatar
Could be a ton of things, even blocked cats!
Check OBD monitors & fuel trims. Cheap & easy
Old May 26, 2021 | 10:13 AM
NYN8IVE's Avatar
Thanks for the reply. The shop indicated all codes had cleared.. Is it a possibility the ECU needs to relearn?
Old May 26, 2021 | 10:36 AM
RJ237's Avatar
I don't think so. All of the ECU rebuilds that I have heard about are plug & play. The drive cycles are for the emission system and not engine performance. Fuel filter, air filter, throttle body, possibly even fuel pump might be at fault.
Old May 31, 2021 | 11:47 AM
NYN8IVE's Avatar
I'm now suspecting its Transmission related even though there's no noises or rough shifts, it intermittently feels like it's in too high a gear (lack of torque) and when I manually shift it feels fine as I go through the gears. I Went back to the repair shop and had the technician drive with me, of course it was fine. He hooked up the scanner and said it came up with a transmission error code (not communicating) and I should drive it over the weekend and come back to check the codes. This is quite frustrating, could TCM be a possible culprit?
Next day I drove about 70 miles on the Freeway and local streets and switched between manually shifting and auto. There were no issues with stalling and no check engine lights over the period of 2 hours and I decided to see if I could get my smog retest. Before rechecking, they plugged a scanner in and it showed 2 codes were still incomplete one for O2 Sensor and one for Catalytic Converter, he said to drive even more to complete those before returning.
Any ideas?
Peter hughes
Aug 27, 2019 02:34 PM
nielda800
Mar 11, 2019 12:17 PM
AMC
Apr 21, 2018 11:06 AM
andrea
Jun 18, 2016 12:10 PM
XK8Lover
May 31, 2012 08:36 AM
