97 XK8 Exhaust System
Old Apr 24, 2019 | 10:28 AM
Airborne's Avatar
Default 97 XK8 Exhaust System
Looking for recommendations for a new exhaust system to give my "too quiet" ride a more "sports car" sound.
Old Apr 24, 2019 | 12:52 PM
DavidYau's Avatar
Default Try dcrautoparts.com
Exhaust mods are always personal choices on sound levels. Stainless upgrades are available too
Try Dave R at this website but be patient when you wait for his response.
Old Apr 24, 2019 | 12:53 PM
avern1's Avatar
Welcome Airborne, I see by your posting count you are a new member. Please take time to post and introduction in the New Member section of the forum ( mandatory). the best way to research the issue is to use the advance search under the SEARCH headding. As a new member you will need to have a minimum number of post before you can use it. Ten I think but it has been awhile since I was new.
The easiest and also the least costly is to remove the rear resonators and replace with a straight pipe. There are many other options and each comes with a trade off, cost, noise level, drone nuisance. I will attach a few of the larger threads so you can get an idea.
https://www.jaguarforums.com/forum/x...uffler-121149/
https://www.jaguarforums.com/forum/x...muffler-21246/
https://www.jaguarforums.com/forum/x...torque-211358/
Again welcome aboard, have fun, there are a lot of folks willing to help. You can also google you tube for different versions of exhaust mods with live sound.
Old Apr 24, 2019 | 10:50 PM
XK8Mojo's Avatar
Default Exhaust mod
After a ton of research on this site and with my exhaust guy that works on a ton of high end stuff and restorations. I went in steps.
1st just remove the center and put in x or h pipe. I did H. It was perfect for a quiet, no drone ride with more bite in the acceleration. Perfect for both wife and me.
Then I went with a full cat-back stainless under axle with new 4 inch tips. I reused just the rear mufflers.
Much louder, a small drone at high way speeds, and looks pretty good.
It is absolutely personal preference. This last system definitely is a bit of a show off sound and sometimes feels a bit overkill when pulling out of the driveway. But it does sound saweet as a sports car
Old Apr 25, 2019 | 01:42 PM
Airborne's Avatar
Thanks, Mojo. That sounds like a sound solution. I'll look into it.
Old Apr 25, 2019 | 07:27 PM
Loxmth's Avatar
I replaced the last two mufflers with the Admish kit. Perfect ,easy and inexpensive.
xjrwithproblems
Aug 10, 2019 07:30 AM
jcboulos
Jan 28, 2013 05:25 PM
pgguy
Dec 19, 2012 04:44 PM
