97 XK8 slow top movement
Old Mar 13, 2016 | 07:04 AM
noterman's Avatar
Default 97 XK8 slow top movement
A friends 97 XK8 top goes up and down but it is very slow. Anything we can check? Thanks
Old Mar 13, 2016 | 07:14 AM
cjd777's Avatar
Fluid in the Pump behind the right side panel, over the CD remote. Should be at the top line.
Lots of information in the DIY area at the top of the Forum.
Wayne
Old Mar 13, 2016 | 07:49 AM
avern1's Avatar
In addition to fluid level you might want to check what type fluid you have in it. Do a search for the fluid changes. There is an older type fluid that gels up and slows down the movement. Also while you are checking the fluid level there is a small petcock on the pump. It is a bypass valve for manual operation. If it vibrates loose it will allow a portion of the fluid and pressure to return to the tank slowing down the operation. Look for a T shaped rod and make sure it is tightly closed.
If you do find the tank low on fluid you should check for leaks in the 2 lifting rams and hoses.
Old Mar 13, 2016 | 10:36 AM
Johnken's Avatar
Should take no more than 20 seconds, unless they installed the voltage reducer to help de-stress the hose pressure. Add 5 to 7 se onds if they did.
ericgiacinto
Jul 4, 2016 02:24 PM
Computer Budda
Mar 22, 2016 02:51 PM
Xj220_
Mar 17, 2016 08:44 PM
Jandreu
Mar 14, 2016 08:34 AM
razorboy
Mar 9, 2016 09:20 PM
