'98 Antifreeze Compatability
Old Jan 31, 2014 | 01:47 AM
fjroze's Avatar
Default '98 Antifreeze Compatability
Ok, Ive read all the threads about the different antifreeze and I really didn't come away with much other than my 98 xk8 was supose to use the Dow542 Yellow stuff. My questions are simple...
1. Is there a name brand easily found product that is the same thing or compatable?
2. If I flush the system, can I use the G 05 Zerex and is that the best choice given my model year?
(I refuse to go to the dealer for anything after they quoted me $1100 to change the radiator hoses and $2100 to change two lower bushings!)
Old Feb 1, 2014 | 04:15 PM
fjroze's Avatar
Anyone?
Old Feb 1, 2014 | 05:46 PM
BurgXK8's Avatar
Originally Posted by fjroze
(I refuse to go to the dealer for anything after they quoted me $1100 to change the radiator hoses...)
Holy crap - I did that job myself on my XK8 when I still had it. I'm not seeing how it could justify that many hours or dollars. You should be able to find a shade tree mechanic who could handle that for a case of beer, for pitys sake.
As for the bushings, I'm not sure - never did those but that job still sounds overpriced. And you should pay attention to whatever color antifreeze it says on the expansion tank/coolant cap area. The color matters. Some anti-freezes are made of different components that could harm an engine not made for them. My XK8 was ok with the yellow or green stuff, if I recall correctly; but my XKR demands the orange stuff to prevent seals from breaking down. It sounds silly but definitely not worth screwing with cooling systems on an aluminum engine. What's your manual say?
Old Feb 1, 2014 | 07:33 PM
Jag#4's Avatar
+1 on staying with the factory recommended color. It does matter.
Old Feb 2, 2014 | 02:45 AM
fjroze's Avatar
Well, factory coolant is yellow Dow542 but the G05 is yellow too. Im not sure color would be a definite answer. All I know is when I bought it I topped it off with green on the way home. Ooops. I think one of the heater hoses is leaking. Trying to track it down now before I drain the system, but want to know what to fill it back up with. Like I said I refuse to go to the dealer.
Old Feb 2, 2014 | 04:41 AM
...... Im not sure color would be a definite answer. .........
Correct. It's not the colour or brand that's the determinand, it's the specification.
On the container label should be the information that it complies with or exceeds ESD-M97-B49-A
This is a Ford standard so you can avoid going to a Jaguar Dealer.
Old Feb 2, 2014 | 09:33 AM
Jag#4's Avatar
Oops. Did I say color? Meant specs.
Graham is correct (as usual).
Old Feb 2, 2014 | 12:26 PM
fjroze's Avatar
Thats great! So my original questions 1 & 2 still apply. Ok, call me lazy for not wanting to read the fine print on every coolant label I can find. Is it a Ford coolant that I have to go to a Ford dealer to get?
Old Feb 3, 2014 | 03:36 AM
...... Ok, call me lazy........
Hello lazy,
You don't have to go to Ford dealer. The coolant is a formulation specification, not a monopoly.
Just as you can buy the same specification oil from different manufacturers, so you can buy the same specification coolant from different manufacturers.
There are two options:
1. Lazy only
buy ESD-M97-B49-A specification coolant from any autoparts retailer
2. Lazy + Rich
send your Gulfstream to NCL airport for me, book me a suite at the Sorrento or Bellevue Club for a week and I'll come to Seattle and do the coolant for you
Old Feb 4, 2014 | 04:52 PM
Mr. Feathers's Avatar
Good for all colors, formulations, cars, etc: Prestone® Extended Life Antifreeze/Coolant | Prestone®
From what I've been told, the bushings will require a press & some serious time, but shouldn't be more than a $1200 job.
Radiator hoses... did they mean ALL coolant hoses in the engine bay??? Even the little ones running under the intake, and the rat nest near the firewall? For thatprice it would make sense.
Old Feb 5, 2014 | 01:30 AM
fjroze's Avatar
Originally Posted by GGG
Hello lazy,
1. Lazy only
2. Lazy + Rich
LOL! It would probably still be cheaper than taking it to the dealer!
And yes Im lazy so thank you Mr. Feathers for a simple answer to a simple question.
Old Feb 5, 2014 | 04:52 AM
plums's Avatar
Absolutely not. Dexcool in disguise.
Old Feb 5, 2014 | 11:13 AM
As I'm no expert on the issue, I would appreciate an education on why this is... especially since I've been running this stuff in my xk8!
My understanding is that Jaguar used "OAT" stype formulations (pre '98 or was it '00? was yellow, but now it's orange). This Prestone formula is supposed to be HOAT, compatible just lasts a little longer.
In my Jag, since I bought it used, I have no way of knowing what they used in the past. When I got it, the coolant looked to be green (inorganic) - and if that is accurate, then I need to flush the system well - because OAT and HOAT do not mix with old fashioned inorganics (they gel up). Also, my understanding is that inorganic used silica which is bad for modern engines.
Old Feb 5, 2014 | 02:26 PM
Jag#4's Avatar
Is there an issue with Dex-Cool? I have been using this since I have owned the blue cat based on info found here on the forum. According to Prestone it is WSS-M97B44-D compatible. Am I missing something?
Old Feb 5, 2014 | 03:20 PM
...I will add that, according to infor found on this forum, the earlier years (up to '00?) did not ome with Dex-Cool. They had a yellow "Jaguar D542" fluid. Google can't seem to find anything about the stuff.
Old Feb 5, 2014 | 03:33 PM
Here's some info on the changeover
File Type: pdf
Old Feb 5, 2014 | 03:37 PM
Jag#4's Avatar
OK, I forgot we were talking about Jaguar engineers and that it would be model year dependent. Makes more sense now.
Old Feb 6, 2014 | 02:35 AM
fjroze's Avatar
So then from what I can tell, no one can definitively answer my questions?
After trying to find information on these so called specifications, I think Ive come to the conclusion that the spec. numbers are just a random set that the manufacturer uses to discribe their product. And they arent going to advertise that its the same as the next guys because they want you to only buy their product. I mean if the D542 has some magical ingredient then they should say so.
So Im gonna go out on a limb here and surmise that if I flush the system very well, it doesnt matter what I use as long as its ok for aluminium and isnt Dexcool. Or am I missing something?
I think the only other option would be to top with something like the Prestone stuff that mixes with anything. I cant see it being the same as Dexcool that mixes with nothing. Or again, am I missing something? I thought it was the Dexcool that could mess up gaskets if it wasnt made to run the stuff in the first place, so I think I want to stay away from that with my MY.
Thoughts? Facts? Any and all would be appreciated.
Trying my best not to come off annoyed, but the manufacturer and antifreeze companies shouldnt make it this difficult. Im just sayin.. its kinda stupid. Ya know?
Old Feb 6, 2014 | 05:36 AM
BurgXK8's Avatar
The only thing you need to do is not screw with an aluminum engine. Use what the manual/expansion tank says. Seriously - it isn't worth messing around.
Old Feb 6, 2014 | 08:14 AM
I agree but what exactly is that in fjroze's case for his '98 car?
I've spent a bit of time searching and didn't find a definitive answer anywhere.
This was interesting Top it Up with Green? Or Orange? Which Antifreeze? - Column - Car Reviews - Car and Driver
