98 XK8 firing order help
Old Mar 2, 2014 | 12:59 PM
dww's Avatar
dww
Default 98 XK8 firing order help
Can't find triangle indent on flywheel, cant get locking tool to fit, can't fit heads back until I know. need to know fireing order
Last edited by GGG; Mar 2, 2014 at 02:41 PM. Reason: edit typo in thread title so it appears in searches
Old Mar 2, 2014 | 01:15 PM
Jag#4's Avatar
From the web. It is also in the stickies on the main forum page in the DIY section.
From JTIS:
Old Mar 2, 2014 | 01:20 PM
Paul Pavlik's Avatar
This may help:
Old Mar 2, 2014 | 02:19 PM
motorcarman's Avatar
DO NOT TRY TO SET CRANK/CAM TIMING AT TDC!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
The oval timing slot is the correct segment to line up in the CKPS mount hole.
The top and bottom of the slot is ROUNDED.
The firing order will not help with cam/crank timing.
bob gauff
Old Mar 2, 2014 | 02:49 PM
dww's Avatar
dww
Thank you all on the forum for your help
Old Mar 2, 2014 | 03:14 PM
dww's Avatar
dww
Thanks Bob for the warning, when I finally found the mark and no pistons were on top I thought that can't be right but it was the only place that the locking tool would fit. I then realized that that the timing was built in (as it were ) to the lock and cams. No timing lights and marks like the old days. Total disaster though as when I checked the exhaust valve clearances they anywhere between .008 to .013 + back to the machine shop and another or more weeks lost. I had not installed the heads yet, that was a good thing. I had a valve head break off years ago on a mark 2, too much valve clearance, took out the whole engine, don't want that again. Thanks again for your help
Old Mar 2, 2014 | 08:10 PM
Did you download the V8/V6 Engine Course 168 that I put in the large file section?????
It is a large .pdf but is all the info you need.
When the valves are 'faced' and/or the seats 'cut' the lash will change.
bob gauff
Old Mar 3, 2014 | 12:20 AM
dww's Avatar
dww
BOb I have been unable to find that pd. computers are not my strong suit, could you give me a link to it.
Old Mar 3, 2014 | 12:41 AM
dww's Avatar
dww
when valves are reseated by machining etc. the lash or clearance becomes a less amount, correct! The shims then have to be adjusted to give a clearance between the bottom of the cam lob and the shim cup with the VALVES SEATED SHOULD BE IN. .2MM or .0078 and .25mm to.3mm or .010 to .011 for the exhaust. How far out of these numbers do you feel it would be safe to run. Bearing in mind that too little will burn the valve over time and too much will beat the head off. T
Old Mar 3, 2014 | 12:45 AM
dww's Avatar
dww
Thanks for your input Bob it is a huge and welcome help.
Old Mar 3, 2014 | 10:24 AM
Follow this link http://www.mediafire.com/?aqxyzo1glqltd
Daim
Nov 28, 2016 09:28 AM
Armor6
Sep 14, 2015 07:56 PM
Armor6
Sep 10, 2015 12:08 PM
Bowman
Sep 3, 2015 03:17 PM
