99 xk8 restricted performance p0300 p1316
Old May 7, 2015 | 01:34 AM
  #61
JagV8's Avatar
Coils don't like damp or oil - pull it and see which it may be. They also just fail with age.
Old May 7, 2015 | 07:39 PM
  #62
Billll's Avatar
Got to work OK but halfway home the RS warning came on. No, erasing the codes isn't the issue, the engine is missing badly, hence the reduced performance. Off and on I got a flashing Chk Eng warning as well his time. When I got in the driveway, I plugged in the reader:
1. P304, cyl 4 miss (might be P0304 or 1304)
2. P1313 Misfire, Cat Converter damage
3. P1316 Injector circuit, IDM codes
4. P0354 Coil D
5. P1111 intake air sensor intermittent high voltage.
Coil D must be associated with cylinder 4. I suppose I could pull the cover and see if the wires and/or connectors are tight. Beyond that I have no idea.
Will trade for Subaru Baja or Ford Transit.
Old May 8, 2015 | 01:23 AM
  #63
JagV8's Avatar
Why not fix it? Sounds likely to be trivial if done soon.
Old May 8, 2015 | 04:01 PM
  #64
Billll's Avatar
Turned out to be easier than I thought. The first code was the clue: Coil #4. The shop replaced it and the following codes were symptoms of the original fault.
Coils cost $125. Putting them in is extra.
Old May 11, 2015 | 08:34 PM
  #65
Hi-Velo-Sid-E's Avatar
Great, good news, and sometimes even bad spark plug(s) can generate dummy codes too.
D.K
Dec 10, 2023 02:05 AM
KarimPA
Sep 27, 2015 08:46 AM
John Fox
Sep 19, 2015 07:56 PM
Johnken
Sep 15, 2015 05:46 PM
XFR_Gold
Sep 2, 2015 12:24 PM
