abs control module help
Old Sep 20, 2012 | 03:43 PM
frederick's Avatar
Default abs control module help
replaced abs control modual on my 1998 xk8. i'm getting a reading{ wrong part fitted},but replaced it with a part that has the same part numbers. need help.
Last edited by GGG; Sep 20, 2012 at 05:52 PM. Reason: edit typo in thread title so it appears in searches
Old Sep 20, 2012 | 05:44 PM
motorcarman's Avatar
The replacement control module needs to be configured to your car.
You need to find someone with a PDU or WDS Autologic etc.
When a new module is introduced on a NETWORK you often need to tell the other modules about the new unit.
Some modules are 'plug&play', some are not.
bob gauff
Old Sep 23, 2012 | 06:37 AM
steveinfrance's Avatar
A common cause is bending a pin on the connector, unplug it and check.
You might also like to read Bob's comments here https://www.jaguarforums.com/forum/x...ow-what-76548/
so you can check the ABS serial number
Steviedee1st
Nov 28, 2023 06:32 PM
XJsc-guy
Sep 25, 2015 11:09 AM
JeffinSwitz
Sep 16, 2015 01:44 PM
BruceG
Sep 15, 2015 05:47 AM
jaguarbill
Sep 5, 2015 11:43 AM
