AC pressure switch location
Old Mar 7, 2015 | 07:46 PM
mrplow58's Avatar
Question AC pressure switch location
Don't mean to look stupid, but I cannot find the low pressure switch on my AC system. Any ideas? My car is a 99 convertible. Thanks again. Maybe someday I will have a computer with the capacity to load files....Be cool....Mike
Old Mar 7, 2015 | 07:51 PM
test point's Avatar
It is on the line at the bottom of the radiator, just about at the middle.
Old Mar 7, 2015 | 07:54 PM
mrplow58's Avatar
They sure make things easy for you, don't they......Thanks again....Mike
Old Mar 7, 2015 | 07:55 PM
Gus's Avatar
Gus
Use this link and look on page 4
Link http://www.jagrepair.com/images/Auto...s/ACSystem.pdf
Old Mar 9, 2015 | 10:58 PM
mrplow58's Avatar
Smile
Ended up being just some corrosion on the plug. I cleaned it off, put some dielectric grease in the plug, added a can and a half of 134 and the AC pressures were dead nuts on. The more I use things, the more the car is coming back to life.
The chain tensioners and cam cover gaskets came today, so it looks like Wednesday is the day for that. I think I will put it on the lift, so I am not bending over for 2 hours.....Thank you again......Mike
Old Mar 10, 2015 | 02:04 PM
apexjag's Avatar
Default Leak
Ignore this...figured out my question was irrelevant.
Old Mar 10, 2015 | 03:12 PM
Gus's Avatar
Gus
On the road again!
Old Mar 10, 2015 | 03:19 PM
apexjag's Avatar
Think I have almost a total freon leak...found a smattering of green-ish oil (looked like compressor oil) just below the drier...think it actually is power steering fluid, and I couldn't see well enough...looked like a freon line with a quick disconnect fitting...doh! So, I'm headed to grab some freon and leak dye to figure out where the problem is...already replaced the pressure switch thinking it is 15 years old anyway. Thanks for reading and being ready to help (although apparently the help I need is mental!
Old Sep 14, 2021 | 12:57 PM
Mudjag2's Avatar
late but not too late, did yiu have to depressurize the system to install the AC sensor below the radiator
Old Sep 14, 2021 | 01:00 PM
Mudjag2's Avatar
did you have to depressurize the system to replace the AC sensor you describe at the middle base of the radiator?
Old Sep 14, 2021 | 01:09 PM
apexjag's Avatar
Unfortunately (but fortunately for me), my system had no freon in it at all once I put the manifold guages on it, so I never had to worry about that. I've put new pressure switches on a 2008 Prius, and a 2010 Mustang, neither of which required me to evacuate the freon. If memory serves, the pressure switch screws into its housing and then depresses a valve (which is closed when the switch is removed) on the way to being screwed in.
Old Sep 15, 2021 | 06:55 AM
piper 888's Avatar
I have a 1998 XK8 and didn't have to evacuate the system to replace the a/c pressure switch because there is a schrader (sp?) valve in the fitting the switch screws into. May be different on newer models.
toronadomike
Jan 22, 2026 10:13 PM
Aus V8S
Nov 13, 2015 11:01 AM
explorer364
Sep 11, 2015 05:44 PM
fingers
Sep 11, 2015 12:21 PM
tonyforman
Sep 10, 2015 07:23 PM
