Accessory relay missing
Old Sep 18, 2024 | 01:26 PM
Jrizzo003's Avatar
Default Accessory relay missing
Seems that the relay labeled “accessory connector relay” is missing - not sure what this controls - and if it should be missing. Strange - and advice appreciated.
Old Sep 18, 2024 | 01:53 PM
Rex's Avatar
Rex
I don’t have one either. Everything works, never modified.
Old Sep 18, 2024 | 01:55 PM
Jrizzo003's Avatar
Thanks!
Old Sep 18, 2024 | 02:15 PM
zray's Avatar
Originally Posted by Jrizzo003
Seems that the relay labeled “accessory connector relay” is missing - not sure what this controls - and if it should be missing. Strange - and advice appreciated…..”
My 2002 XKR coupe has the same arrangement. Everything works fine .
What year is your car ? Coupe or convertible ?
Z
PS are you missing the battery hold down strap ?
Old Sep 18, 2024 | 05:50 PM
michaelh's Avatar
That relay is not normally present unless the auxiliary power sockets (cigar lighter socket in the glovebox and boot) have been added. There are instructions for this on member Gus' site:
http://jagrepair.com/images/AutoRepa...owerSocket.pdf
...although, strangely, the relay itself doesn't get a mention.
Old Sep 18, 2024 | 11:50 PM
markdpeter's Avatar
I've put some stuff in this thread about how I used these accessory feeds... Read down the thread.
https://www.jaguarforums.com/forum/x...ighter-281521/
Old Sep 19, 2024 | 03:09 AM
dibbit's Avatar
I used the connector in the boot to supply my back up camera - I didn't need to add a relay. There are two 12v supplies in the accessory connector, one is switched on the ignition (via the missing relay) and one is permanent on, so no need for the relay. You would imagine that the Jaguar accessory socket kit is ignition switched, but maybe not.
Old Sep 19, 2024 | 05:44 AM
Jrizzo003's Avatar
Old Sep 20, 2024 | 04:59 AM
michaelh's Avatar
Thanks. I should have looked closer.
Both of the kit harnesses being separately inline fused & the non-mention of the relay certainly point to unswitched B+.
Bowmanconsult
Jan 8, 2024 02:23 AM
rgp
Jul 16, 2023 01:51 PM
69jaguar
E type ( XK-E )
Nov 23, 2021 09:11 AM
rgp
Jun 27, 2019 05:29 AM
JensenHealey
Feb 25, 2017 07:20 PM
