Adaptive CATS shocks vs standard shocks?
Old Oct 20, 2021 | 01:32 PM
Kuddlesworth's Avatar
Originally Posted by bcprice36
Kuddlesworth,
Don't know for sure but that's probably what they call the "R" Package on the newer Jags.....
Billy Clyde
I guess so.
Old Oct 26, 2021 | 07:10 AM
crtfour's Avatar
One of the wires got twisted and broke on my CATS rear shock which sent the car into a suspension fault/stiff mode. I just decided to replace them with standard shocks. The other side rear wire was twisting as well and probably wouldn't have been far behind. I have 20" BBS wheels and honestly don't note any ride difference. My primary reason for the standard shocks, though, was that it's a 20 year old British car and I'm not getting any younger and just like to simplify things when the opportunity arises.
Old Oct 26, 2021 | 08:39 AM
Jon89's Avatar
I fully understand. Cost-effective simplicity beats expensive complexity in these aging cars every time....
Old Oct 26, 2021 | 11:51 AM
That was also my thinking, I also have the 20" wheels. I don't need to replace then as of yet but when I do I will have to make a decision. I assume if you downgrade you have to remove the CATS module in the boot so no fault codes display.
Old Oct 26, 2021 | 02:21 PM
crtfour's Avatar
IIRC I believe the module is still there, but simply unplugging it will remove the fault message. That's what I did when the wire broke and I got the message since CATS was inoperable at that time anyway.
Old Oct 26, 2021 | 11:22 PM
Makes sense thanks. Would you say the car has more body roll in corners now that the CATS has been removed or can you not relaly tell any difference. I don't corner the car to it's limits but it's nice how flat the car stay around a corner at the moment.
Old Oct 27, 2021 | 02:52 AM
dibbit's Avatar
The default setting for the CATs is hard mode, so you won't get more body roll in corners, your body will feel it over bumps though.
Old Oct 27, 2021 | 04:49 AM
  #28
crtfour's Avatar
For the driving that I do, which also includes some curvy back roads, I personally don't note much of a difference. It seems a little more soft with normal driving, which I like. I'm sure I took it into more extreme curves I'd notice a difference but I haven't tried it yet.
Old Oct 27, 2021 | 04:51 AM
crtfour's Avatar
Interesting, I thought the default was soft mode. I ask because once I got the fault the car got and stayed very stiff, which for me was a motivating factor to get the problem taken care of.
Old Oct 27, 2021 | 11:40 AM
  #30
I did try it by unplugging the front shocks. It was a very harsh ride, far too harsh. I didn't get much above 20mph it was that bad.
Old Oct 28, 2021 | 02:08 AM
  #31
dibbit's Avatar
The default mode is hard - for safety you don't want soft shocks if you are going to be driving at speed. I did wonder about your comment where you said you couldn't tell the difference when you removed the CATs after they went into fault mode - you replaced stiff shocks with stiff shocks.
Also its worth bearing in mind that not every fault on the CATs system displays the fault message. A broken wire to a shock will trigger the message. A faulty sensor won't.
jlbsam
Apr 20, 2017 02:41 PM
greenforest56
Aug 11, 2016 03:32 AM
pjdarcy
May 3, 2016 12:05 PM
garryatabex
Feb 22, 2014 08:32 AM
hrand1987
Aug 18, 2011 03:47 PM
