Advice please ... on what parts to pre-order
Old Apr 8, 2016 | 08:55 PM
Bhpbug's Avatar
Question Advice please ... on what parts to pre-order
Hi guys, Having rebuilt my front suspension last week, I am planning to re-do the rear next. I have seen a few posts from people who have replaced the foam rubber cushions around the top of the shock shaft... I suspect these deteriorate like the ones on the front mounts... ( gotta be a better material than this) My question is, since I'd like to pre-order the parts I need, will I also replace the foam cushion under the top of the spring? Should I order the 3 foam parts for each side ,or 2 ? I am planning to use MOTORCARMAN's method of shock removal. Thanks in advance.
Old Apr 9, 2016 | 07:21 AM
Addicted2boost's Avatar
Replace the 6 foam pieces (3 on each side) on both rear shock mounts.
Old Apr 9, 2016 | 08:35 AM
Ungn's Avatar
The Bilstein Shocks are complete and include all the foam and new boots. You just bolt them in and the rear is done.
Then just clean/re-grease the bearings in the lower hub and you are good for another 100K miles.
Old Apr 10, 2016 | 12:54 AM
jamdmyers's Avatar
You don't have your car model/year in your signature so...
If a XK8 foam replacement maybe enough, though the blistiens mentioned are only about $100 ea, includes all new bushes/foam.
If a XKR you have adaptive damping, these are 350 ea, so just a bush/foam replacement maybe the best choice.
btw. The half-shaft u-joints should be greased yearly.
Probesport
Jun 23, 2017 03:20 PM
Bhpbug
May 3, 2016 12:26 PM
WhiteJag
Apr 5, 2016 03:22 PM
Travis O'Gallagher
Apr 3, 2016 02:49 PM
kenatofc
Apr 3, 2016 10:42 AM
