Aftermarket Coil packs for a 2000 XKR
Old Aug 11, 2016 | 10:11 AM
arush's Avatar
Default Aftermarket Coil packs for a 2000 XKR
Has anyone used any aftermarket coils on their XKR with success ?
I have a 2000 XKR with approximately 83,000 miles on it. Over the past couple of years I have replaced (2) coils with factory Denso coils (at $100.00 each) and they have been fine. This past weekend I got a code showing a different coil pack issue.
I would like to replace all of the coil packs and keep the two Denso units for backup.
I appreciate all feedback.
Old Aug 11, 2016 | 10:24 AM
I installed a complete set of these about 2 years ago and still going strong
For 1997 2003 Jaguar Vanden Plas XJ8 XJR XK8 XKR V8 Ignition Coil New | eBay
Old Aug 12, 2016 | 05:38 PM
arush's Avatar
Appreciate your input Steve.
Old Aug 12, 2016 | 06:20 PM
VinceCh's Avatar
I installed a set of these in my 2000 XKR last March. Ignition Coils on Plug Pack for 1996 2003 Jaguar Vanden Plas XJ8 XJR UF415 8pcs | eBay
I think I paid a little more than the asking price of $95.00 for a set of eight. They're doing their job just fine, so far. Quite a bargain so long as they continue to work properly.
Vince
Old Aug 14, 2016 | 01:48 PM
arush's Avatar
Appreciate your input Vince.
Old Aug 14, 2016 | 02:27 PM
80sRule's Avatar
I did the same $100 set of 8 coils for my XKR around April of this year and they're all good. Nowhere near all of mine were bad so I keep the good ones around as parts, but these seem a ok. My A8 has $15 each coils going on 5 years and they're great.
Old Aug 14, 2016 | 06:18 PM
Don-T's Avatar
Default Beware
I got a couple of the no-name ebay coils, one to use and one for a spare. The installed one seems to work fine and looks the same as the others. Make sure you know whether you need two wire or four wire coils before you order them.
Old Aug 15, 2016 | 10:22 AM
arush's Avatar
Appreciate your feed back 80s Rule and Don-T.
I think I am going to give them a try and keep my (2) new ones from the dealership as spares.
Old Aug 15, 2016 | 10:59 AM
brgjag's Avatar
on my 03 xk8 should I get PRO ACTIVE and replace mine at 106k on them? No issues but should I do some preventive replacing of these and plugs/wires?
Old Aug 15, 2016 | 11:14 AM
arush's Avatar
Vince,
It is my understanding that sometime in the year 2000 was the cut off date between the AJ26 2 pin style and the AJ27 4 pin style coils.
My car has the 4 pin style coils.
Are the coils that you ordered from Selected Auto Parts the 2 pin or 4 pin style?
Thanks....
Old Aug 16, 2016 | 05:59 AM
VinceCh's Avatar
arush,
My 2000 XKR uses the 4 pin style coils. I hope this helps.
Vince
Probesport
Jun 23, 2017 03:20 PM
julesjag1
Apr 23, 2016 01:42 PM
Roger B
Apr 21, 2016 12:57 PM
hm1
Apr 5, 2016 08:49 AM
AllblueACR
Mar 26, 2016 02:12 PM
