Air bag code 1 7
Old Sep 4, 2020 | 11:24 AM
Russ1965's Avatar
Default Air bag code 1 7
Hi all,
I am nearing completion on my 2003 for but have ran into a snag. The airbag light on the dash has started flashing the 1 7 code(I believe it to be the occupancy sensor??). Has anyone had this fault and , or, has anyone sorted the problem?? I have recently installed a new headlining and the light has been showing ever since.
cheers
Russ
Old Sep 4, 2020 | 11:40 AM
Welcome to the forum Russ,
If you tell me what model your 2003 is I'll move your post to the proper tech section.
Old Sep 4, 2020 | 02:21 PM
Russ1965's Avatar
hi Norri,
sorry my tablets predictive text changed the lettering. I have a 2003 xkr 4.2 supercharged. I've had a lot of work done it's looking brilliant just this niggle with the airbag light. Any help greatly appreciated.
cheers
Russ
Old Sep 4, 2020 | 02:52 PM
Here you go, you are right 17 is an occupation sensor fault.
Old Sep 6, 2020 | 06:26 AM
Russ1965's Avatar
Many thanks for the reply Norri,
I have now traced and cured the fault. I found the sensor plug in the passenger A Pillar to be loose. Just as a note to other owners the plug felt like it was ok but it needed to be connected so you hear the lugs click into place. When I reconnected everything I thought it was ok but obviously not.
Old Sep 6, 2020 | 02:10 PM
Jon89's Avatar
Well done....
Andy Cox
Jan 4, 2017 03:11 PM
xtype62
Jul 25, 2016 02:49 PM
Smooth1Bham
Sep 4, 2015 02:19 PM
JagYour
Nov 19, 2014 02:21 PM
Jandreu
Jun 2, 2014 03:32 AM
