Air conditioning
Old Jul 16, 2015 | 02:11 AM
oyster's Avatar
Default Air conditioning
Hi all.
My aircon has stopped cooling with a code B1858 which could be low refrigerant charge. How do I figure out if it is a normal slow leak over time, or if it is a gross leak that needs repair before I spend money on recharging.
Old Jul 16, 2015 | 02:50 AM
Do you use the AC much in Norway?
Expect to lose approximately 5% charge each year. The only way I'm aware of to check for leaks is with a tracer dye.
When I have my AC recharged, the machine they use does the following:
1. remove residual R134/PAG oil
2. pressure test
3. re-charge with correct weight R134/PAG oil
In the one instance I had of a car failing the pressure test (2), they used a dye to find the source so i didn't pay for the re-charge (3) until it was fixed.
Old Jul 16, 2015 | 03:18 AM
oyster's Avatar
Hi GGG.
Thank you. Exactly the information I was looking for.
Of course I use the AC here in Norway. Today bright sunshine and 25C. No problem though, I will go with the roof down.
Old Jul 16, 2015 | 01:10 PM
Jag#4's Avatar
At 77F (25C) I would have the top down too. It will reach 100F (38C) here today. I may still keep the top down, we'll see.
Enjoy what sounds like great weather!
Old Jul 16, 2015 | 01:39 PM
oyster's Avatar
Hi Jag#4.
With that temperature you'll need AC in your cap.
I know what it's like. Many, many years ago I spent a year in Lubbock.
Old Jul 16, 2015 | 02:37 PM
brgjag's Avatar
mine stopped working, I just went to the local auto place and threw in a can and it has been working fine now for 4 or so months. I have done this with many of my cars through the years and have never had one that was shot and leaked out in a day or so. I always got a year or two out of them then had to top them off again.
I have my 74 Olds 88 convert, didn't come with AC so the tops goes down today on the way home.
Old Jul 16, 2015 | 09:06 PM
chopr's Avatar
Look at the refrigerant line that comes across the back of the motor and kind of below the coolant reservoir. I have replaced a number of these due to leakage at the crimped sleeve where the hose goes from rubber to metal.
Old Jul 17, 2015 | 09:03 AM
oyster's Avatar
Default Update
Hi all.
Went to a specialist today and he told me it was very low on charge, probably normal after some years. He also told me if it had been completely empty, that would indicate a leak.
Refilled and now nice and cool in warm Norway.
So now I will hope it holds up.
Old Jul 17, 2015 | 06:14 PM
brgjag's Avatar
I would make a point of turning it on from time to time even when you don't need it. I feel that keeps the system in use, less chance of it leaking out????
Old Jul 17, 2015 | 08:56 PM
Gus's Avatar
Gus
I leave my A/C on all the time and just adjust the temperature.
Old Jul 18, 2015 | 06:57 AM
+1
Me too. I also cycle it from max Hot through max Cold once a month.
Old Jul 18, 2015 | 11:11 AM
Gus's Avatar
Gus
This is what i used to find my leak when i rebuilt my A/C system
Link Electronic Freon and Halogen Leak Detector
xjrjag
Oct 24, 2024 03:09 PM
Rivguy
Dec 4, 2020 07:55 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
SCMike
Sep 9, 2015 09:30 AM
mikelibera
XJ40 ( XJ81 )
Sep 4, 2015 05:17 PM
