Airbag code 15?
Old Jun 19, 2011 | 01:12 PM
seawind's Avatar
Default Airbag code 15?
Does anybody know what airbag code 1 pause 5 "15" is? I've been searching the forums but can't find any information on it. The vehicle is a 2003 XK8.
Thanks!
Old Jun 19, 2011 | 04:50 PM
test point's Avatar
The air bag codes are found in the FAQ Sticky above under 'air bag codes'. Unfortunately, a 15 is not listed, goes from 13 to 16. A search of JTIS OBDII codes for each year may produce the missing ones.
Old Jun 19, 2011 | 05:11 PM
motorcarman's Avatar
Here is a TSB that might be of interest to you!!!
bob gauff
File Type: pdf
Old Jun 20, 2011 | 09:13 AM
H20boy's Avatar
dang, that's a good air bag code document Bob, linking that directly to the FAQ on airbags!
seawind, you sure its 1-5, not 5-1...a sealt belt buckle sounds much more plausible (spilling of a drink into it) and cheaper to fix/replace than the restraint module. <--- yikes!
Old Jun 20, 2011 | 11:17 AM
seawind's Avatar
Thanks Bob! Just what I needed.
h20boy, Yes it's definitely 1 - 5 I've stared at it for to long now haha, I'm assuming the restraint control module and airbag control module are one in the same. The list price is $970 even with my discount it costs $770 and I can't find any on eBay or anywhere, bummer. Its part number c2n3057 it supersedes part c2n4285 I believe.
Have any idea on how much the dealer charges to flash one of these things?
Old Jun 20, 2011 | 11:32 AM
WhiteXKR's Avatar
I suggest inspecting for loose connectors, loose connector pins and damaged wiring before shelling out the big bucks for a replacement module.
Jpav27
Jul 31, 2022 06:43 AM
Johnken
Sep 15, 2015 05:46 PM
34by151
Sep 6, 2015 05:14 PM
AL NZ
Sep 4, 2015 08:39 PM
