Alignment question
Old Aug 4, 2020 | 02:33 PM
Redeye's Avatar
Default Alignment question
Front ball joint covers are being replaced tomorrow. Have asked for the tracking to be checked as well.
From memory, is the recommendation to have both fronts set around 1' toe in? Cant find anything in my notes file, but I'm sure having this setting helps compensate for the natural movement outwards on travel, thereby diminishing the dreaded inner tyre wear.
Thanks, Jules
Old Aug 4, 2020 | 02:45 PM
Jon89's Avatar
I follow the advice of forum member "Brutal" (he is a long-time Jaguar tech in Houston, Texas). Here is what he recommended for XK8 alignment a few years ago:
"Set the front toe to .16 on both sides instead of the more typical .12. I see too much front tire inner edge wear at the typical .12 setting."
That has indeed worked for me for the past several years....
CZSteve
Sep 2, 2019 10:19 AM
DC73
May 18, 2015 11:33 PM
Karaudio23
May 6, 2015 09:41 PM
sneal46
Jul 21, 2014 09:53 PM
CortComp
Mar 24, 2012 02:55 PM
