Aluminum Thermostat Housing
Old Jun 25, 2023 | 03:47 PM
JACKP's Avatar
Default Aluminum Thermostat Housing
Are all after market XK8 aluminum thermostat housings Equal?
Prices seem to range from $39.00 to $90.00 US. Any best brand recommendations?
Also, does anyone make an aluminum cross over pipe?
Old Jun 26, 2023 | 01:54 PM
MiragePro's Avatar
I just purchased the cheapest one on eBay two years ago and holding up fine. I also replaced the bolts with Torx screws. It made it much easier to reassemble. Not sure about the crossover pipe.
Old Jun 26, 2023 | 02:13 PM
JACKP's Avatar
Thanks MiragePro, they all look the same. Just don't want to replace plastic with a cheap piece of junk if you know what I mean.
Jack
Old Jun 26, 2023 | 02:36 PM
michaelh's Avatar
The aluminium replacement is only for the 4.0L
Old Jun 26, 2023 | 03:04 PM
RJ237's Avatar
And there is only a plastic cross pipe, which is OEM.
Old Jun 26, 2023 | 04:36 PM
JACKP's Avatar
Michaelh, are there no problems with the 4.2 housing like the ones on the 4.0. I guess otherwise someone would be making them.
Jack
Old Jun 26, 2023 | 04:58 PM
michaelh's Avatar
AFAIK, they're made from the same biodegradable stuff, so no reason to expect they'll last any longer. Consolation is the crossover is part of the assembly:
Haven't read much here re replacements - possibly because the 4.2s are up to 7 years or so younger, and there's no alternative.
Lifespan on a par with the hoses that connect to them, I guess.
Old Jun 26, 2023 | 05:52 PM
JACKP's Avatar
Thanks for the drawing michaelh. Looks like it would be easier to get to the rear bolts on the 4.2. My Jag has just over 30000 miles on it so hopefully it's miles and not years that gets them.
Old Jun 26, 2023 | 07:29 PM
xalty's Avatar
if you have a 4.0 just put the plastic one on it lasts 15 years. or at least get o-rings from the dealer and don’t use the pos cardboard gaskets the aluminum one comes with
Old Jun 26, 2023 | 08:02 PM
JACKP's Avatar
Mine is 2005 4.2. If they last 15 yrs mine is past due. Again hopefuly Miles takes more of a toll on them than years. If so maybe I still have a while before it needs changing.
Old Dec 30, 2025 | 12:26 AM
Brian G's Avatar
Got my Ebay sourced housing today. The packaging was first rate and the castings appear to be quality products. Lets hope the fitment is as good.
Hazmat1075
Oct 21, 2022 09:09 AM
Stamford
Aug 23, 2020 01:40 PM
Mokong
Jan 27, 2013 04:00 PM
ez64
Jul 25, 2011 10:38 AM
jimlombardi
Apr 8, 2011 08:35 PM
