Am I missing a piece of carpet?
Old Jan 27, 2012 | 02:08 PM
Frog's Avatar
Default Am I missing a piece of carpet?
In the trunk there are various bits of carpet, but the vertical rear piece (hiding the fuel tank) seems very loose along the top edge. There is basically nothing holding it in place.
My question is: is there supposed to be a piece of carpet suspended horizontally below the parcel shelf around where the sub sits? There seem to be stud holes in the painted metal and I'm wondering if the carpet fell out at some point and was discarded or lost by the previous owner.
Old Jan 27, 2012 | 02:29 PM
Frog,
If you are - so am I.
I think we can safely say 'no'.
Old Jan 27, 2012 | 02:36 PM
Checking the Parts Manual.......
............it's a definite 'no'
Old Jan 27, 2012 | 02:40 PM
Paul Pavlik's Avatar
My car only has the Vertical Panel behind the tank. The Sub Woofer is visible. Some cars also have a Cargo Net mounted in that area. My car dosen't have one though.
Old Jan 27, 2012 | 05:05 PM
test point's Avatar
WD 40, Duct Tape and Velcro.
Old Jan 28, 2012 | 02:43 AM
Frog's Avatar
Thanks for your replies, guys. I guess this is going to have to be the solution:
Old Jan 28, 2012 | 01:13 PM
Frog,
I've had a closer look at the carpet today.
Refering to the Parts Manual JPG in my earlier post, the rear carpet (3) is held in place by vertical grooves in the side sections (1) and (5). There's no glue / velcro / clips at the top and it's sufficiently rigid to be self-supporting.
Old Jan 28, 2012 | 01:25 PM
xenophobe's Avatar
See, if you had a vert, you'd have a piece of carpet that covers that area. loool
Old Jan 28, 2012 | 09:47 PM
This shows the mounting for a Cargo Net. The upper part of the Panel includes 2 mounting pegs that must be screwed into some metal "Brackets".
Note: This is a Convertible.
Old Jan 29, 2012 | 03:49 AM
Frog's Avatar
I haven't got the net. Were they standard fit on the coupé?
Old Jan 29, 2012 | 04:40 AM
NO - the 'S' or 'V' models had almost all the available options fitted as standard but the nets are accessories.
dsnyder586
Dec 29, 2024 07:39 PM
King Charles
Apr 16, 2017 11:10 AM
Poet
Oct 6, 2015 09:40 PM
SeanU
Sep 14, 2015 04:31 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
