Ambient Air Temp sensor
I noticed that the ambient air temp sensor was painted when I had my car resprayed. Is this effecting my climate control system?
I'm not getting any errors.
It is easy to check the sensor. Press the control on the temp for an outside temp reading, if it close it is good. When I couldn't get heat in mid-December I found the outside temp was reading 136 degrees with snow on the ground. Replaced the sensor and all was good. They are very inexpensive and easy to change.
King Charles
Apr 19, 2016 08:25 PM
