Anatomy of an engine mount
Old Mar 31, 2021 | 06:08 PM
baxtor's Avatar
Default Anatomy of an engine mount
I have a failed engine mount and in the process of changing it out thought a breakdown of the components within may be of interest.
pics show the main body, the bladder, valve plate and the upper section of mount.
Upper section normally includes the fixing stud which has separated on mine, hence the failure.
l am not sure what fluid is used in these mounts but some use a mix of water and glycol.
Old Mar 31, 2021 | 09:15 PM
ccfulton's Avatar
Thoughts about possibly replacing it with a solid polyurethane or rubber version of the same dimensions?
One assumes that some day these liquid filled things will no longer be available.
Old Apr 1, 2021 | 07:52 AM
cjd777's Avatar
Charlie, I can tell you if looking for dimensions when you look up different parts of OEM mounts, there will only be the size of the shipping package.
The stores sometimes do have the length on their computer, best just have a buddy at Autozone and let you go through the boxes.
Or, be like me and just keep getting what looks like it might fit and buy it. Well, not really that bad but the only way sometimes.
Nedoerr
Nov 22, 2022 08:01 AM
Buickcadillacman
Nov 15, 2021 01:43 PM
MattArnold
May 25, 2020 03:49 PM
kazi
Feb 24, 2020 08:46 AM
Spikepaga
Jun 5, 2019 05:19 AM
