Annoying Dash Squeak
Old Feb 3, 2016 | 12:16 PM
Elgrosso's Avatar
I too have some strange noise sometime in my convertible.
It took me long time but I found them:
- inside the header rail panel (not sure of the name here), the top trim part of the windshield. I had a broken plastic clip
- central mirror, same here, one clip was broken
You could also check: seat rails, door panels (inside), seat belt clip
And it can also be something in the rear, one of the worst to find in my coupe was... the 3rd brake light! Broken by UV, got loose etc
Old Feb 3, 2016 | 08:10 PM
giandanielxk8's Avatar
I finally figured out the source of my squeak. The drivers side upper shock mount failed prematurely. The donut bushing seems to be in good shape but the strut is out of place. Perhaps the shims on the plate broke off.
I'm going to contact SNG Barratt about it, the part is less than two years old. The other part is still in good shape.
Old Feb 5, 2016 | 07:31 AM
Stamford's Avatar
Congratulations on locating the squeak. A tiny, intermittent noise like that is like water torture. You can spend all you time in the car obsessing over it. The bright side, though, is seeing how many members jumped in to offer help. We all feel your pain.
Old Feb 28, 2016 | 10:23 PM
Flcat's Avatar
Default Same dash squeek
Any new ideas? Please help.
Old Feb 28, 2016 | 10:33 PM
Flcat's Avatar
Default Dash noise
giandanielxk8, When you pushed down in the fender did you hear the noise? I finally figured out the source of my squeak. The drivers side upper shock mount failed prematurely. The donut bushing seems to be in good shape but the strut is out of place. Perhaps the shims on the plate broke off.
Old Feb 29, 2016 | 05:40 AM
Addicted2boost's Avatar
The moderators have instructed to start a new thread instead of using someone else's post.
However, here's the answer to your problem... Front upper shock mounts.
Old Feb 29, 2016 | 12:27 PM
Flcat's Avatar
Default The squeak is gone!
I'm happy and dancing, the squeak is gone!
giandanielxk8 gave a great tip when he said it ended up being a bushing. I never would have believed that. I would have bet it was from the dash. But after reading about the bushing idea, I woke up the next day and sprayed WD 40 on the top of the struts and turned the front wheels both ways and sprayed every bushing I saw. That was it and the squeak is gone! THANK YOU!
Old Feb 29, 2016 | 12:33 PM
  #28
Jon89's Avatar
You know the WD-40 is just a temporary fix, right? As soon as your residual WD-40 evaporates, your car will get noisy again....
Old Feb 29, 2016 | 01:59 PM
Flcat's Avatar
Default Dash sqeak
Can you please recommend a better lubricant spray? Thank you.
Old Feb 29, 2016 | 04:31 PM
  #30
Jon89's Avatar
Lithium white grease spray. But sooner or later you're going to have to replace your worn-out bushings, and there's a bunch of them on these cars....
Old Jul 18, 2021 | 10:29 AM
  #31
LondonGirlDXB's Avatar
Originally Posted by giandanielxk8
I have this annoying unidentified squeak in the interior that occurs while driving at any speed as long as the car is moving over anything less than smooth asphalt. It sounds like a creaky door hinge or like a cricket that loves ***** cats.
I've only had it for about a week and it is driving me to the loony bin.
Here's a video where it can be heard.
oh my god I have the same and it has been driving me mad, sometimes worse than others, did you find out what the problem was?
Old Jul 18, 2021 | 10:17 PM
  #32
Front upper shock mounts as seen in post #22 of this thread.
Old Jul 19, 2021 | 10:49 AM
  #33
Flcat's Avatar
I am not an expert, but I had an annoying squeak on my 2002 XK8 and it was the bushings on top of the front shocks.
Old Jul 19, 2021 | 01:27 PM
  #34
RichardPratt's Avatar
Had the same problem. Turned out to be the the passenger side upper shock mount. Shock was off center
iconic
Apr 22, 2016 05:24 AM
Lothar52
Feb 12, 2016 03:39 PM
JagTheRipper
Feb 4, 2016 04:13 AM
Stentplacer
Jan 29, 2016 04:49 PM
Uncle Fishbits
Jan 29, 2016 02:36 PM
