Annoying error codes ...anyone solved theirs?
Old Oct 16, 2015 | 11:18 AM
zidjan's Avatar
Default Annoying error codes ...anyone solved theirs?
Hi guys,
I know there are some of you have lived with some annoying codes that's never go away...I got some too ...I wonder if you guys have ever solved any of these? Thank's fellas
P0110 intake air temperature sensor circuit
c1300
p2200
u1041 SCP Speed signal - invalid or missing data
B1595 ignition switch - illegal input
u2012 communication bus error
u1135 ignition status not obtained
b2323 local mirror drive, left/right out of range low
b2327 local mirror drive, up/down out of range low
b24bd diagnostic trouble code invalid
p0562 system voltage low
U1262 scp (J1850) communication bus fault
Old Oct 16, 2015 | 11:50 AM
WhiteXKR's Avatar
Have you tried to clear them and see which, if any come back ? Often they they set if components are removed doing service while the battery is still connected and will remain until cleared.
Old Oct 17, 2015 | 07:33 AM
JagV8's Avatar
In a 10yr old car some could be 10 yrs old.
With a voltage low fault some others could be fake, caused by the low volts.
So, +1 on clearing and see what happens.
Old Oct 17, 2015 | 10:54 AM
brgjag's Avatar
low volts = battery change?
Old Oct 17, 2015 | 02:01 PM
JagRag's Avatar
My advice would be to simply ignored them if they do not effect drivability of the car.
Old Oct 18, 2015 | 11:55 AM
JagV8's Avatar
That's OK except damage can be occurring even though all seems fine (classic example is burning out a cat conv).
Any code that recurs wants attention...
Old Oct 18, 2015 | 12:03 PM
Gus's Avatar
Gus
I would be looking at the battery and connections.
Gus
www.jagrepair.com
Originally Posted by zidjan
Hi guys,
c1300
p2200
Old Oct 18, 2015 | 07:30 PM
zidjan's Avatar
I tried to clear it...but my ingenuity scanner keep telling me ...failed to clear dtc.
My first suspect is also the battery...is there any way we know that the battery is at it's end of its life?
I guess I could ignore it but I don't want to be ignoring the important ones if I am ignoring that dang "SC system fault"
Old Oct 18, 2015 | 09:05 PM
Gus's Avatar
Gus
Go to autozone, Advanced Auto or Sears and have the battery tested for free then see if they can clear your codes.
Bigvettefreak
Oct 24, 2015 08:47 PM
BFSmith
Oct 17, 2015 09:09 PM
BFSmith
Oct 17, 2015 04:59 PM
Jagman28
Oct 17, 2015 04:24 PM
nurquhar
Oct 17, 2015 06:41 AM
