another ? where is mount for CMPS
Old May 28, 2022 | 09:08 PM
stevepaa's Avatar
Default another ? where is mount for CMPS
instruction says to mount the Crankshaft Position Sensor CMPS on the plate that the throttle body sits on. I do not see any clip for that.
Old May 28, 2022 | 10:03 PM
motorcarman's Avatar
CMPS is CAMSHAFT POSITION SENSOR.
CKPS is crankshaft position sensor.
Old May 29, 2022 | 12:12 AM
stevepaa's Avatar
yes I meant camshaft
Old May 29, 2022 | 07:34 AM
JayJagJay's Avatar
I'm a little confused. On the two cars (XKs) that I've worked on the position sensor was mounted under the engine and trans in a little mounting hole on the front side of the bell housing. Then, the wire ran (from memory) forward (towards the front of the car) to join into a larger wiring harness that came up the LH side of the engine...
Are you talking about cam shaft position sensors?
Old May 29, 2022 | 08:01 AM
The CMPS is mounted in the rear of the cylinder head.
The harness CONNECTOR has a mount tab that fits into a bracket you are describing.
Old May 29, 2022 | 09:44 PM
stevepaa's Avatar
yes CMPS and my throttle body does not have the tabs to connect. I am going to get them from a junker
Old May 30, 2022 | 08:51 AM
Most of those mount tabs were never transferred to a NEW/REPLACEMENT throttle assy during repair.
Throttle problems were common when I worked at the dealer during that time.
Nedoerr
Nov 22, 2022 08:01 AM
MisplacedPriorities
Sep 4, 2021 12:57 PM
kazi
Feb 24, 2020 08:46 AM
martin fothergill
Mar 19, 2010 09:13 PM
