Antenna motor noise ?
Old Aug 23, 2021 | 01:37 PM
KRT's Avatar
KRT
Default Antenna motor noise ?
So this just started happening on my XK8, turn on the radio, antenna raises and just before it gets tot he top it makes this weird clicking noise? this goes on for about 30 seconds after the antenna is all the way up. I have lubed it up with WD40 now numerous times, turned the antenna back and forth (saw a youtube video) but the sound doesnt go away. Any thoughts? thanks
Old Jul 18, 2022 | 03:42 PM
KRT's Avatar
KRT
thought id resurrect this to see if anyone had any input
Old Jul 19, 2022 | 09:22 AM
Perhaps a piece broken off the end of the plastic strip of 'teeth' on the bottom of the mast?
Today's noise can easily become tomorrow's breakage so I'd be taking the motor cover off to check inside.
Old Jul 19, 2022 | 04:52 PM
KRT's Avatar
KRT
Thanks Graham, i will do just that. Appreciate the insight
Old Jul 20, 2022 | 11:20 AM
Brett_in_PA's Avatar
I ended up replacing mine. There are lots of universal fit antennas on ebay that will work fine but I found an OEM Jaguar used with a warranty for less than $75.
Old Jul 23, 2022 | 06:20 AM
Pistnbroke's Avatar
The click is the overrun clutch.Quite normal. perhaps it is not fully extending due to damage on the aerial bit .usually clicks a couple of times at the top and bottom
Old May 20, 2023 | 12:24 PM
KRT's Avatar
KRT
Thought id post an update on this, purchased an antenna on eBay for $25. Followed the instructions for replacing the mast from a previous post on this site. Total time involved 5 mins. Works like new. Love anytime its a DIY project.
Old May 20, 2023 | 04:26 PM
SeismicGuy's Avatar
I've been dealing with for the last month or so and I think I also posted about it. Sounds the same as what you were getting--mast goes up fine but then about 15 seconds of noise after it is up (sort of clicking, motor sound) and then it stops. Going down there is no noise. I suspect it is some problem with the last bit of mast and will eventually get around to replacing the mast.
Old May 20, 2023 | 05:07 PM
KRT's Avatar
KRT
Was the same with mine, seriously its a 10mn job max to replace the mast.
Old May 21, 2023 | 12:53 PM
SeismicGuy's Avatar
I know the mast replacement is quite easy as I have done this on other cars I have owned. But then again I was thinking nothing is "easy" with the Jaguar so I have been stalling it off. Did you find a preferred replacement from all of the choice on ebay and elsewhere?
Old May 27, 2023 | 05:59 AM
KRT's Avatar
KRT
no i just made sure it was compatible with my cars year and model.
Pilotman11
Nov 20, 2015 07:49 AM
chip
Feb 7, 2012 10:34 AM
TopHatChef
Feb 6, 2012 01:49 PM
guzzi svt
Jun 3, 2010 01:20 AM
