Anti Seize To Help Install Wheel Hub?
Old Mar 12, 2012 | 06:33 PM
bsprowls's Avatar
Default Anti Seize To Help Install Wheel Hub?
Doe anyone have any experience with using a little bit of anti seize on the front wheel hub when pressing it into the new bearings?
Old Mar 12, 2012 | 08:26 PM
MRomanik's Avatar
Veteran: Air Force
Had a shop do mine today.Don't think they used anti seize.
Old Mar 13, 2012 | 03:54 PM
bsprowls's Avatar
Thanks for the input. When pressing in the new front hubs I purchased to the new front bearings, there seemed to be alot of resisitence. So we added a bit of peratex anti seize to the shaft of the hub & it went in alot smoother. Still have the other one to do but wanted some opions (after the fact - duh) of whether or not anyone has done it this was or did I make a mistake as maybe the hub won't be gripping the bearing as well as it should. Any more ideas on this?
dsnyder586
Dec 29, 2024 07:39 PM
H20boy
Dec 24, 2024 03:23 PM
JagLove86
Sep 6, 2015 10:36 PM
Joey T
Sep 3, 2015 05:31 PM
innzane
Sep 2, 2015 10:08 AM
