Antifreeze odor
Old Apr 11, 2020 | 12:38 PM
Moosehead's Avatar
Default Antifreeze odor
am getting antifreeze odor when driving and after stopping Does not appear to be coming from radiator or any signs in the exhaust. Am losing some antifreeze from expansion tank. I am planning to change thermostat housing replacing the plastic housing - any heads up on doing this Would appreciate some input on further checking or solutions
______________
2001 XK8 (added by GGG)
Old Apr 11, 2020 | 01:41 PM
Fraser Mitchell's Avatar
What car ? For the V8s, the coolant header tank and thermostat housing are the most common places, but supercharged V8s have a pipe between the V which also gives way, and also gives a lot of grief due to the labour charges to fix a $10 pipe.
Old Apr 11, 2020 | 01:48 PM
I've added vehicle details from your profile and moved your question from General Tech Help to XK8/XKR forum. Members here with the same model will be able to help.
Old Apr 11, 2020 | 02:25 PM
avern1's Avatar
The coolant smell is obviously a leak. The only way to find a hidden leak is to perform a pressure test on the cooling system. You will probably find that the heater inlet or outlet hose is leaking. Since the leak will flow into the valley area of a hot engine and boil off you only get the odor. It could also be at any connection near an exhaust area. That would also boil off the fluid.
I recommend the Harbor Freight test kit for radiators since it has the right adapters.
Old Apr 11, 2020 | 07:28 PM
dennysjag's Avatar
Default Valley hose maybe culprit.
Valley or the dreaded octopus hose.
don't be intimidated you can fix it.
A genuine pita but do-able for sure. I did them so most should be able to
Old Apr 11, 2020 | 07:56 PM
crbass's Avatar
One common place is all of the hoses/reservoir above the left cat. Drips onto the cat have been the bane of one of my cars. Both the hoses from the heater matrix, and the reservoir have appeared at different times. So, with everyone else's suggestions, essentially any of the hoses above hot things....
Second the pressure tester.
Old Apr 12, 2020 | 09:08 AM
JimmyL's Avatar
Talking
There are a couple of "norma" connectors above the cats that connect to the octopus hose. A drip here is pretty common (after years) and it will evaporate quickly. You can look around on top of the cats in that area for orange residue or staining. There are threads on here about replacing the o-rings to fix this leak - at least temporarily. Here's one -
https://www.jaguarforums.com/forum/x...ctopus-215787/
chip
Dec 2, 2014 10:50 PM
GA-Chuck
May 11, 2014 10:20 AM
majbill
Dec 20, 2010 09:09 AM
JVANNOZZI
Apr 4, 2010 07:08 PM
summerwind
Oct 9, 2009 07:31 AM
