Any ideas if or where this should go?
Old Aug 1, 2022 | 08:09 AM
Phil m's Avatar
Default Any ideas if or where this should go?
I was just adding some coolant to the car and checking for leaks when I found this sat loose just above the supercharger.
Any ideas what it is and where it should shouldI can check?
Old Aug 1, 2022 | 09:13 AM
PKWise's Avatar
That is a Temperature Sensor. Look up this part number LNA1600AA
Old Aug 1, 2022 | 09:32 AM
Phil m's Avatar
Thanks PKWise.
https://www.berkshirejagcomponents.c...aa-c2x22661633
Considering I was given a "coolant low" warning recently is it fair to assume I still have one installed?
Old Aug 1, 2022 | 09:37 AM
dibbit's Avatar
Originally Posted by Phil m
Thanks PKWise.
Surely if you didn't have one installed there would be a puddle of coolant under your car? Your temp gauge would be pegged also, The coolant low warning is from the sensor in the coolant filler tank, which is known to fail.
Old Aug 1, 2022 | 09:40 AM
PKWise's Avatar
Everyone correct me if I'm wrong. but I think that Coolant sensor goes here on an XKR ? Unsure- I've never removed it myself
Old Aug 1, 2022 | 10:22 AM
Phil m's Avatar
Thats virtually where I found my one sitting.
Old Aug 1, 2022 | 12:39 PM
Phil m's Avatar
Thos is what is currently there.
Old Aug 1, 2022 | 12:59 PM
giandanielxk8's Avatar
Someone replaced the sensor and seems to have left the old one as a souvenir.
AJB2
Apr 17, 2019 11:35 PM
Jst2gtby
Oct 14, 2018 07:47 PM
Jst2gtby
Jst2gtby
Oct 14, 2018 06:18 PM
F12guy
Nov 10, 2017 07:41 AM
