Auto Levelling Headlights question
Old Feb 16, 2012 | 11:01 AM
malbec's Avatar
Default Auto Levelling Headlights question
When I start the engine the headlights rise and then sink down again.
Just wondered if this is normal. The levelling arms on the suspension appear to be intact.
My dipped beam does appear to be too low.
Could someone please confirm, or not, that this is normal behaviour for the auto system.
Thanks.
Old Feb 16, 2012 | 11:20 AM
Brutal's Avatar
Its normal, but if theyre too low you have to manually adjust them them to correct height. This manual setting it what the units level too, not some other setting.
Old Feb 16, 2012 | 01:06 PM
Brutal,
What's the adjustment procedure?
My levelling is operating OK but the left hand dipped beam is set far too high.
Old Feb 16, 2012 | 04:12 PM
jamjax's Avatar
+1 3G's request for the procedure please my right beam is too low.
cheers,
jj
Old Feb 16, 2012 | 06:14 PM
Originally Posted by malbec
...............My dipped beam does appear to be too low......................
Unless Brutal comes back and says otherwise, adjustment looks to be a simple procedure using a hex wrench:
Headlamp Adjustment - HID.pdf
This next one gives a slightly better view of the adjustment screw:
Headlamp Levelling Motor - Vehicles with HID.pdf
Old Feb 17, 2012 | 12:35 AM
jamjax's Avatar
Thanks G;
Does anyone know the answer to this question??
Do you know if this adjustment hex screw works for both the hi and low beams?
Because the hex screw looks like it is on the hi beam barrel only.
Great tip in the HID-PDF that you must have the car running to properly do this.
cheers,
jj
Old Jun 20, 2013 | 07:46 AM
monster48's Avatar
I have the same problem. Replaced the battery and now my headlights are in the down position. how do I re-program them?
Old Jun 20, 2013 | 01:45 PM
Is this on your 2000 XKR?
I didn't think self-levelling HID's were available for that MY.
Old Jun 21, 2013 | 08:05 AM
RaceDiagnostics's Avatar
I used this thumbwheel for individual headlight levelling.
Old Jun 22, 2013 | 07:16 AM
monster48's Avatar
Thanks Guys. Listed my new car. Its a 2003 XKR Love it Just had to replace the battery and everything went out of sink. All systems go now. Having some transmissions issues, jurk at stop. Will have the trans fluid changed this week. Looking for a set of 19 or 20 wheels. Have to replace rear top hoses.
Wolfy
May 28, 2024 08:06 AM
way2far
Aug 31, 2022 09:26 AM
sklimii
Sep 5, 2015 06:04 AM
laserguy
Sep 3, 2015 02:02 PM
King Charles
Sep 3, 2015 12:40 AM
