Back side window problem
Old Apr 21, 2022 | 05:31 PM
ship52's Avatar
Default Back side window problem
For the last while have been manually lowering the roof until I get around to replacing the hydraulic lines. The problem is the two back side windows will not come up. Any thoughts on what could be the problem,
Thanks for any help.
Lance
Old Apr 21, 2022 | 05:37 PM
ship52's Avatar
Default Window problem is on a 1999 XK8
On XK8
Old Apr 29, 2022 | 04:57 PM
dcarlo's Avatar
when you are raising the top, the micro switches on the ram is not being made. You can either "jump"the relays, left and right to raise the windows, or reach in and pull the frame and the ram up to the locked position so the windows will raise with the top switch. If you do that, you will have to gently push the ram down slightly to unlock it to manually lower the top. See your owners manual for instructions on manual raise and lowering the top. I hope this helps answer your question.
Jim Stewart7
Aug 12, 2018 03:56 PM
Hanso
May 6, 2017 09:56 AM
Terry Alan
Jul 19, 2013 09:05 AM
CzarZiggy
Feb 10, 2012 11:24 AM
rrnc
Oct 4, 2007 07:45 PM
