ball joints
Old Oct 27, 2014 | 08:40 AM
tony bosco's Avatar
Cool ball joints
hello forum... does anybody know how to tell if you need ball joints... my uppers have a slit in them on both sides and i was told thats normal ?????? front end is tight tires are wearing evenly dosen't seem to have a problem when driving even at high speeds... confused a bit.................... any advice maybe i should just have it checked out................. theres no grease leaking out of anywere either ??? thanks
Old Oct 27, 2014 | 02:59 PM
RaceDiagnostics's Avatar
I guess its pretty tricky to tell if they are on their way out till they are well gone.
I couldn't tell that these two had any problem till I split them from the hub.
www.youtube.com/watch?v=wSM64UY87ks&feature=youtu.be
Old Oct 27, 2014 | 03:19 PM
bamforp's Avatar
Split gaiters on ball joints is usually an instant MOT fail here in the UK which is why I had to change out my lower front ball joint a while back (there's a post on here somewhere). Once moisture can get in and the grease can get out, it's only a matter of time before corrosion causes the joint to fail, potentially catastrophically. If they were on my car, I would be planning to change them out pretty soon.
Old Oct 27, 2014 | 06:08 PM
tony bosco's Avatar
Cool ball joints
i'm with you.... tks
TreVoRTasmin
Feb 23, 2021 03:13 PM
JagBrian
Oct 1, 2015 12:52 AM
JAMES1944
Sep 29, 2015 11:58 AM
Camnelson324
Sep 27, 2015 08:48 AM
Woznaldo
Sep 26, 2015 11:02 AM
