BBS Perseus Wheel Refurbishment
Old Nov 21, 2015 | 10:37 PM
01Silverstone's Avatar
Default BBS Perseus Wheel Refurbishment
Hey all
I know there's plenty of threads here regarding the trim-ring replacement, and I've obtained 4 new rings, as the ones on the car when I bought it are all slightly scuffed or damaged.
However, around the center cap on 2 of the wheels, the finish is flaking off a bit. My question is on refurbishing the actual wheels themselves once they're apart. Anything special here, or can a normal alloy refinishing shop handle the job?
Also any other tips I should make my mechanic aware of when removing the wheels? He's a JLR master tech, so he's very familiar with the cars, but may not have done any BBS wheels in awhile.
Old Nov 22, 2015 | 06:48 AM
The Perseus split rim construction looks similar to the Sepangs I had on my last XK8.
Once taken apart, refinishing process for the alloy is the same as for one piece wheels. The problem is often removing the titanium bolts without shearing them or stripping the threads in the wheel. My local wheel refinishing specialists were happy to take on the work but at my risk if anything broke during the dismantling.
Old Nov 22, 2015 | 07:00 AM
JgaXkr's Avatar
Originally Posted by 01Silverstone
Hey all
I will be surprised if your technician has ever repaired a BBS wheel as the parts were never available to purchase. Jaguar had a deal with BBS to send the wheels to them for repair. They would charge a flat fee to repair them. They would take the wheel apart & replace the trim ring and barrel if needed. If the hub was bad the wheel would be scrapped. The problem now is they no longer repair the wheels. If you need any hardware I should have what you need.
Old Sep 5, 2022 | 02:08 PM
chucksci's Avatar
Exclamation BBS wheels
I need the trim rings replaced on my wheels.
Please advise
Chuck
Old Sep 6, 2022 | 05:31 PM
crtfour's Avatar
Chuck, when I replaced my trim rings, I got them from here : https://jagwheeltrims.co.uk/
For the refinishing, I sent a couple of my Sepang wheel faces off to be refinished to Wheel Wizard in Atlanta, GA (they came recommended from someone on here). It was easy shipping them because I had the faces separated from the barrels while replacing the trim rings. I think they charged around $125 per wheel, but that was back in 2018. They did a superb job and the refinished ones perfectly match the others.
Old Sep 7, 2022 | 11:26 AM
CA Jag's Avatar
So far, no wheel repair shop in the Sacramento area will work on replacing the XKR trim rings. Any Bay Area suggests?
Refinishing alloy wheels is 175-225 in the Sac area.
Old Sep 9, 2022 | 04:49 PM
chucksci's Avatar
I wish to sell my 2006 XKR Victory Edition, 37,000 miles, Black, Black, Black convertible with the curbed BBS wheels. Any ideas of value?
Chuck
Hunter Jag
Sep 9, 2022 05:56 AM
kstevusa
Jan 26, 2015 01:48 PM
David's XKR
Jul 3, 2014 09:06 AM
johncdawson
Mar 12, 2014 01:23 AM
oldmots
Aug 7, 2013 09:21 AM
