Bench Test Throttle Position Sensor
Old Aug 2, 2021 | 01:15 PM
thom4782's Avatar
Default Bench Test Throttle Position Sensor
Hi all:
I purchased a used TPS b/c I/ trying to avoid buying a new or used Throttle Body. Are there any test I can try without installing it in the car to see if it's likely to work. For example, can I measure the resistances across pins. If so, what pins and what should on expect as values? Thanks
Old Aug 2, 2021 | 05:46 PM
See this TPS Replacement thread:
https://www.jaguarforums.com/forum/x...acement-77560/
alfaholic
Jan 13, 2024 06:58 AM
fredd60
Oct 21, 2019 07:46 PM
fredd60
Mar 10, 2019 09:01 PM
04vdp
22
Feb 8, 2018 08:29 AM
N224WR
Apr 1, 2011 12:30 AM
