Best brake set up 2005 XK8
Old Jun 10, 2021 | 08:14 AM
Kenny34's Avatar
Default Best brake set up 2005 XK8
I will have to do my brakes soon. Are the drilled and cut rotors with ceramic pads the best way to go? What are the pros and cons? What paint do you use to paint the calipers?
Old Jun 10, 2021 | 09:20 AM
fmertz's Avatar
Best is to definitely upgrade to the later XKR setup with 4-piston calipers, even if front only (you asked for best).
Staying with the stock setup, drilled rotors are nice under wet weather. The braking action feels immediate, instead of being slightly delayed while the water is swept away on the plain rotor. Plain rotors are technically "better" in the sense they have marginally more mass and therefor marginally lower temp for the same dissipated heat. Brake Performance claims that slots somehow changes the brake dust dynamic and leads to wheels not getting as dirty. Reality is that it is more a question of personal preference. One thing to keep in mind is that the cheaper drilled rotors come as 1 part#, and the better ones come as 2. This has to do with the drilling pattern: with one part#, the drilling is what it is (maybe looking "forward" on one side and "backwards" on the other) whereas the 2 part# have mirror image drilling pattern.
For pads, it is probably a discussion like conventional vs. synthetic oil. Short version is that ceramic is great for everyday driving as it produces less visible brake dust. Semi metallic is the performance option but leaves that black/greasy dust on your wheels. FWIW, the single piston setup of the XK8 is arguably marginal on the car as it is at speed, so a performance pad is kind of the way to go, but you know your own driving pattern and can go from there. As usual, the design of the stock braking system is to allow a safe emergency stop from top speed to zero one time. Performance parts come in when you want a higher standard.
Best of luck, keep us posted.
Old Jun 10, 2021 | 05:41 PM
zray's Avatar
For street use, I don’t think the plain vs drilled rotors is going to be a meaningful performance difference.
Until I find a better pad, I’m sticking with the ebc red stuff pads. Been using them on many different vehicles.
Low dust & a substantial improvement in stopping distance over the OEM pads. I’ve found them to be very easy on the rotors.
I have about 50,000 miles on the ebc red stuff pads on my ‘02 XKR. I replaced the rotors at the same time. The pads have about 50% of the friction material left. My driving is about 50% highway / 50% in town. The rotors look same as new.
Z
Old Jun 10, 2021 | 06:34 PM
Just Another Guy's Avatar
Hey Z - Which rotors did you use? Thinking of upgrading (or at least replacing) in the next year or so. Was thinking maybe the Bosch rotors and a set of decent pads.
Thanks,
Norm
Old Jun 10, 2021 | 07:27 PM
zray's Avatar
I got the rotors from RockAuto.com
The ebc red stuff pads came from Amazon
Old Jun 11, 2021 | 09:17 AM
dfbender's Avatar
Z
Zray, what rotors did you buy? Also what model/PN EBC red stuff pads did you get?
Old Jun 11, 2021 | 12:50 PM
zray's Avatar
Note: I don’t have the Brembo brakes, just the base (ATE) system for the 2002 XKR
the pads are:
front: ebc redstuff pads # DP3689/2C
rear: ebc redstuff pads # DP31198C
front rotors: Stop Tech Sport Rotor 127.20015 L / R
I can’t locate the number for the rear rotors.
these parts numbers are from 2018, they might be superseded by now.
the stop Tech rotors are just the best RockAuto had at the time. I know you can get better ones, probably ebc branded ones, etc from summit.com
Let me know what you end up with and how it works for you.
Z
Old Jun 11, 2021 | 01:46 PM
dfbender's Avatar
the pads are:
Z
will do and thanks for the info.
Old Jun 12, 2021 | 08:33 AM
ccfulton's Avatar
I think very highly of https://brakeperformance.com
I opted for the dimpled and slotted vs drilled and they are dip coated so are protected from rust even inside the vanes.
Old Jun 15, 2021 | 10:38 AM
TropicCat's Avatar
My 2 cents ... I had braking problems in wet & cold weather with my Sebring Convertible a few years ago and upgraded to slotted & drilled rotors (combo). I bought a cheap pair of rotors off e-bay. They worked fine for the 20K miles I used them. I also installed the Hawk semi-metallic street pads. They have a very soft compound and wear fast but they stop great. The rotors & Hawk pads definitely made a difference under the conditions I was having problems with but they never completely solved the problem. Never figured out what caused the problems before I sold the car. Anyway, I like the drilled rotors for appearance but the slotted definitely perform better than the solid or the drilled. The down side is that they wear the pads faster. I guess that's the price of better stopping power.
I also "upgraded" my semi-metallic pads to ceramic on my old Hyundai and discovered that I actually lost braking power (using the original solid rotors). The ceramic pads make a lot less dust but they also increase your stopping distances. In my case it was significant. The original semi-metallic pads stopped the car a whole lot faster and in a lot less distance than the ceramics. I was so disappointed in the ceramics that I went back to the semi-metallic pads after a few weeks. I just didn't want to give up the stopping power. I bought Raybestos pads for both the ceramic and the sem-metallics. The "hardness" rating on both the ceramics and the semi-metallics were the same (I don't remember what they were now - EE or FF or whatever). The semi-metallic pads definitely stop better. Both pads worked and didn't squeal but the ceramics just didn't stop quickly enough for me. I'll stick with the semi-metallic.
Good luck.
zidjan
Jul 17, 2015 02:09 PM
mbates50
Dec 24, 2012 01:20 PM
stevis05
Mar 8, 2010 02:28 PM
Stevil
Oct 4, 2008 05:12 AM
Xman
Jun 19, 2008 10:21 AM
