Best Oil filters
Old Nov 6, 2013 | 07:47 PM
MFoncerrada8's Avatar
Default Best Oil filters
I recently linked from this forum into a page where someone had evaluated oil filters....a significant evaluation where he had cut and measured the filter elements....etc.
I can't seem to find the link.
Does anyone know what I'm talking about? If so, can you please point me at it?
tnx
Old Nov 6, 2013 | 10:49 PM
Never mind....I found Baldwinds on eBay for $13 B1435
Old Nov 6, 2013 | 11:12 PM
Doug's Avatar
I'm usually a bit non-chalant about this sort of thing but I've heard great things about the Baldwin filters. Apparently they have a great reputation.
I never heard of 'em until I started dabbling in Ferrari servicing....which, judging from your signature, is how you learned about them as well
Old Nov 7, 2013 | 12:56 AM
Originally Posted by Doug
...I never heard of 'em until I started dabbling in Ferrari servicing....which, judging from your signature, is how you learned about them as well
Quite true.....the Ferrari community obsesses about everything....and in filters they insist on Baldwin or UFI...so I'll just take their word for it....
Old Nov 7, 2013 | 04:38 AM
ArtyH's Avatar
I believe a genuine jaguar filter has a non return valve which stops oil draining back into the engine and thereby helps protect the motor on start up. Not all after market filters had the non return valve. You pays your money.....
Old Nov 7, 2013 | 10:29 AM
aode06's Avatar
In a test on every oil filter, known to man including Jaguar,the Bosch premium oil filter.
has been deemed the best in the world.
YOU AINT FIND ALL THIS INSIDE A JAGUAR FILTER.
Exclusive FILTECH media technology
Screens out more harmful contaminants for greater engine protection
Stronger steel baseplates and housings
Prevent warpage, leaks and poor fit
Silicone anti-drain back valve
Ensures a supply of clean oil when you start your car
High lubricity gasket design
Provides a tight seal, yet easy removal
Double-locked rolled seam
Forms a leak free canister
CHECK OUT http://www.boschautoparts.com/Filter...s/Filters.aspx
Old Nov 7, 2013 | 03:13 PM
mike66's Avatar
Oil Filters - Bob Is The Oil Guy
Have fun!
Old Nov 7, 2013 | 03:38 PM
Jon89's Avatar
Fun indeed. One could OCD for days on that site....
Old Nov 7, 2013 | 07:23 PM
JTsmks's Avatar
Here tis, old but good
http://wetwesties1.tripod.com/oilfilterstudy/
Old Nov 7, 2013 | 11:15 PM
Engine Oil Filter Study
Thanks! that's the one I remembered seeing...
Old Nov 8, 2013 | 05:32 AM
ArtyH's Avatar
Just checked to see if I could get a Bosch oil filter in the U.K for my 1999 XK8 which appears to be a bosch 72209 premium ( ? ) according to the U.S specs, just out of curiosity. Looks like its easier to get hold of hens teeth
Old Nov 8, 2013 | 11:39 PM
plums's Avatar
Thumbs down
That would be a straight copy and paste from the Bosch publicity blurb right?
In the real world, the Bosch listing for the 4.0L engine differs in dimensions from the Jaguar original part. It is shorter so that it will fit both the side mount filter pad and front mount filter pad applications. This bit of catalogue number engineering lets them use one part to cover two interchanges. They are also much lighter new than the equivalent Mann filter.
No thanks. Bought two, used two. Not buying any more.
Old Nov 8, 2013 | 11:40 PM
plums's Avatar
count yourself lucky
Old Nov 9, 2013 | 04:10 AM
ArtyH's Avatar
Talking
Thanks for that Plums, and noted, I have a genuine Jaguar filter which hopefully will be fitted late next week when I get the tensioners done ( weh hey ) together with fuel filter and drive belt. It will give me a chance to test the gearbox also. BTW are you on the edge U.K or US? LOL's
Cheers,
ArtyH
aholbro1
Dec 29, 2024 06:46 PM
Scarecrow
Mar 28, 2016 03:17 AM
axr383
Sep 18, 2015 11:19 AM
teacoff
Sep 10, 2015 08:25 AM
pnwrs2000
Sep 3, 2015 11:55 AM
