Black headed valet key? - RESOLVED
Old Apr 29, 2020 | 04:40 PM
Per's Avatar
Per
Default Black headed valet key? - RESOLVED
I have two black headed keys with transponders. One (older and worn) will unlock the luggage compartment (boot) whilst the other (newish looking) will turn about 45 degrees and no further so does not open the boot. Is that how the valet key is supposed to function? It should be added that the newish looking key looks like a fresh version of the old, it does have the "step" at the tip unlike some valet keys I have seen photos of. Is the lock extremely sensitive to the size of the step?
Last edited by GGG; Apr 30, 2020 at 10:09 AM. Reason: Add "RESOLVED" to thread title
Old Apr 29, 2020 | 08:46 PM
DavidYau's Avatar
Per,
Yes, the trunk lock is very sensitive to the key. I converted my green valet key to a master black key by grinding to make the step at the end of the key. Took a few attempts so that it fitted the trunk lock.
In your case, it sounds like a previous owner had a second master key made, but the cut step at the end isn't quite right. It's a 2 min job to correct using a needle file or Dremel to adjust the step in the tip.
Old Apr 29, 2020 | 09:14 PM
motorcarman's Avatar
LOOK AT THE KEY TIP!!!!
The only difference is the tip of the key.
Old Apr 30, 2020 | 05:23 AM
The BLUE sections are identical on both MASTER and VALET keys. The difference is the RED section is turned down on the MASTER:
That's why a VALET can be converted to a MASTER but a MASTER cannot be converted to a VALET key.
I often wonder who at JLR thought that was the secure way to do it instead of the other way round!
Old Apr 30, 2020 | 09:32 AM
Per's Avatar
Per
Thanks, a few minutes with a file did the trick.
Old Nov 2, 2020 | 01:08 PM
66RBS's Avatar
Default valet key
Originally Posted by DavidYau
Per,
First a clarification on my part
Valet keys are green. Are you referring to the plastic grip or the the background in the "cat" logo? All my keys are black but 2 have green background in the cat logo.
But I am beginning to think all my 3 keys are valet keys since none will open the lid but function correctly otherwise.
So my question is the step down cut on the valet key. GGG posted pictures but I can't see the difference. The length of all the keys is the same. I think you are referring to the height of the wedge at the tip. Correct? Assuming they are 1/8" tall now I assume you grind a valet key to a smaller dimension.
Randy
cornhusker66
Aug 9, 2018 04:42 PM
malc4d
Feb 1, 2016 09:39 PM
BillDJohnson
Jul 31, 2013 09:09 PM
resneed
Dec 21, 2011 05:07 PM
mrtalkradio
XJ40 ( XJ81 )
Sep 21, 2010 06:10 AM
