Blinker Noise (or lack of it)
Old Apr 1, 2011 | 09:07 AM
Reverend Sam's Avatar
Default Blinker Noise (or lack of it)
My turn signal is so quite that I sometimes find that I've driven for miles with my turn signal on. Is there any way to make it louder?
Old Apr 1, 2011 | 09:15 AM
H20boy's Avatar
mine is so loud people i talk to on the phone often ask me which direction I'm going to turn.
Old Apr 1, 2011 | 09:16 AM
That makes me think there has to be a way to adjust it.
Old Apr 1, 2011 | 09:38 AM
K.Westra's Avatar
Mine is jussssst rigggght
Old Apr 1, 2011 | 09:50 AM
H20boy's Avatar
maybe the PO stuck a tube sock over the turn signal flasher relay
Old Apr 1, 2011 | 10:20 AM
WhiteXKR's Avatar
Lots of the system warnings, incuding the blinkers are driven by the BPM to a speaker in the steering column. It would not surprise me if the BPM volume is digitally programmable by the dealer.
Guess you could also just put a cheap audio amp on it such as:
Hi-Fi Stereo Amplifier Car Music Power Audio 2CH Amp | eBay
Old Apr 1, 2011 | 10:23 AM
SeismicGuy's Avatar
I agree with Sam. Most cars I have owned have the blinker volume just loud enough so that you are aware that it has actually gone on when you move the stalk. For the Jaguar, I often have to look at the instrument panel and see the blinking arrows to confirm that the blinker is on. Being able to adjust the sound would be great.
Doug
Old Apr 1, 2011 | 10:50 AM
Tiko89's Avatar
Mine is almost silent, too. In my neighborhood I'm the guy with the Jag who drives around all day with his turn signal on. I've wondered if this might be related to the fact that I can barely hear my backup warning?
Old Apr 1, 2011 | 10:56 AM
Martin's Avatar
This is a little off thread. May flashers have two speeds. When I first turn on the turn signals it has one speed, but after running for a short time it speeds up to about twice as fast. I thought at first in was an indication of a burnt bulb. I Doen't have a burnt bulb unless it is intermitent and I have been looking at the right time. Why?
Old Apr 1, 2011 | 10:58 AM
Paul Pavlik's Avatar
Don't bother. Just get old and move to Florida!
Old Apr 1, 2011 | 02:58 PM
itspec60's Avatar
If you figure out how to get the blinkers louder then how about getting the alarm system chirp louder.
Old Apr 1, 2011 | 03:49 PM
xenophobe's Avatar
My alarm system doesn't chirp. And yeah, half the time I'm not paying attention, my turn signal has been on for a while. lol
Old Jun 12, 2013 | 06:21 AM
TreVoRTasmin's Avatar
Anybody figure out how to make the turn signals louder and the alarm chirp? Mine xk8 a quiet, well silet kitty.
Old Jun 12, 2013 | 10:45 AM
SeismicGuy's Avatar
In addition to these am still wanting the "one touch up" window feature that apparently was standard on 2006 XK8/XKR and is currently standard on most cars.
Doug
Old Jun 12, 2013 | 10:50 AM
giandanielxk8's Avatar
My blinker noise is silent, I can't hear a peep. I've gotten so used to it that I can drive no more than a minute with it on. I also don't have the door ajar noise, the key in ignition noise or the car isn't in park or neutral when it's not running noise. So basically, the only sounds I hear inside my cabin are road noise, radio/iphone and the person in the other seat, if there is one.
My alarm does work beautifully though.
Old Jun 12, 2013 | 10:54 AM
Brizzy's Avatar
Mines the same, probably all going deaf except for H20boy
Old Aug 3, 2015 | 06:32 PM
garryatabex's Avatar
Default jaguar xk blinker noise (or lack therof)
Hi Sam,
Did you ever get an answer for this. Mine makes a noise every couple of months- dead silent otherwise. Thanks.
Garryatabex
Old Aug 3, 2015 | 08:15 PM
WhiteXKR's Avatar
Sam sold his car many moons ago.
If you look at the right side of the steering column you will see some perforations in the plastic. A small speaker sits behind there. There are two deep holes under the column that have phillips screws. Remove them and the plastic steering column shroud top and bottom can be removed.
Then you can check and jiggle the wires to the speaker and see if you have an intermittent connection.
Old Aug 29, 2015 | 07:35 PM
Felipe Pr's Avatar
Anybody followed XKR recommendation with success?
Old Jan 4, 2016 | 04:40 PM
ReluctantMechanic's Avatar
Does anybody have a wiring diagram for the X308 to chase down the speaker - could there be a fuse set separate for the blinker speaker? My indicator lamp speakers suddenly stopped working. I will pull the speaker per instructions here in.
Everyone who rides with me likes the distinct blinker sound.
