Bolt removal issue - right front lower control arm
Old Dec 17, 2018 | 01:42 AM
Higgins's Avatar
Default Bolt removal issue - right front lower control arm
I'm in the process of replacing springs, ball joints and bushings on my Xkr coupe - 2000. When disassembling the front right lower control arm I ran into a problem, the bolt will not come out due to hitting what I think is a mounting for the front subframe, see picture below. Does anyone know the solution to this?
Regards,
Higgins
Old Dec 17, 2018 | 02:18 AM
baxtor's Avatar
Regards,
Higgins
l did the same job on my own coupe a little while back and recall that bolt will wiggle out past the mount. Loosening off the other side at same time may allow more movement of the tie brace.
Old Dec 22, 2018 | 05:45 AM
Higgins's Avatar
Thank you for the advice Baxtor. But now I tried to remove the bolt for the rearward mounting of the lower arm and guess what.. Same issue there but only worse.. 😣 The bolt hits the steering rack, see picture below. At the other end seems to be a lot more space, has this bolt been inserted the wrong way, or is it normal procedure to remove the steering rack for being able to remove lower control arm?
Old Dec 22, 2018 | 09:00 AM
cjd777's Avatar
Higgins, I have not done this job yet, but have read the steering rack bolts need to be loosened for removal of that bolt.
Odd how much has to be removed to get things done on the modern cars.
Old Dec 22, 2018 | 10:34 AM
rothwell's Avatar
The attached document covers the need to loosen the steering rack. Other helpful info in there too with good pictures.
File Type: pdf
Old Dec 23, 2018 | 02:16 AM
Higgins's Avatar
Great, thanks for the advice both of you. New try within a few days..
Old Jan 16, 2019 | 07:01 AM
Higgins's Avatar
Yes, it worked 😀 Get the arm off now
Thanks all!
Old Jan 16, 2019 | 08:16 AM
volkris's Avatar
Any tips to share, @Higgins, while the procedure is fresh in your mind?
Old Jan 16, 2019 | 08:19 AM
Higgins's Avatar
When it comes to the steering rack, I only removed the steering rod, not the rack itself. The rod was in the way of the bolt of the control arm, but with the rod out of the way the bolt also came out. And with the rear bolt out, the arm was able to wiggle a bit so that the stuck front bolt also came out
Gary G
Aug 13, 2025 12:59 PM
kblood
Mar 2, 2022 11:40 AM
zak
Oct 13, 2015 11:46 AM
Jagnubbie
XJ XJ12 ( X305 )
Mar 27, 2014 03:17 AM
calvindoesntknow
Aug 2, 2013 06:22 PM
