Boot lid shut , battery disconnected!!!
Old Mar 17, 2012 | 09:35 AM
nilocp's Avatar
Default Boot lid shut , battery disconnected!!!
I am just in the process of changing the micro switch on the drivers door, so have the battery disconnected. Boot lid is now shut and will not open!!
Any brilliant ideas on releasing the boot lid please??
Colin
Old Mar 17, 2012 | 09:55 AM
WhiteXKR's Avatar
Look between the 'X' and the 'K' on the badge on the boot...there is a cleverly disguised keyhole there to open the boot with the key.
Old Mar 17, 2012 | 11:26 AM
nilocp's Avatar
Aah! You are nevr too old to learn!
I did open it by putting the battery charger on the stud under the bonnet, but thanks.
Colin
Old Mar 19, 2012 | 08:00 AM
steveinfrance's Avatar
Colin
You were lucky to get away with that. With no battery to buffer the voltage it's a miracle you didn't fry the electronics.
Even re-connecting the battery has to be done carefully (one positive push on rather than a tentative series of jabs).
I've not fried a Jag brain but have done in a Toyota (€1000 for a new one) with a bad battery charger.
Old Mar 20, 2012 | 05:52 AM
nilocp's Avatar
Might not have got away with it! It was only on for a few seconds, at very low current. Byt now I cannot lock the doors and the mirrors dont work.
Going to try a 'hard reset'
CP
Old Mar 20, 2012 | 06:12 AM
nilocp's Avatar
Tried the hard reset. It worked
Dont know how, but it worked. Everything back to normal again.
CP
Old Mar 20, 2012 | 08:13 AM
CP
Phew, you were lucky. Glad it's OK
Old Mar 20, 2012 | 08:53 AM
Paul Pavlik's Avatar
A excellent Point. Many Battery Chargers use little filtering on their DC Output. The result is Peak Voltage readings well above 14 Volts, capable of damaging Electronic Circuits. Of course, with the Battery Connected, the voltage will be "Clamped" at a reasonable level.
H20boy
Dec 24, 2024 03:23 PM
Malihide
Apr 2, 2016 04:05 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
DuhCar
Sep 11, 2015 10:58 AM
