Brake pad ?
Old Apr 16, 2013 | 03:33 PM
randyb's Avatar
Default Brake pad ?
Went to order brake pads and rotors for the rear and the asked me if I had small clips or large.
So without take the calipers off, is there an easy way to tell?
Old Apr 17, 2013 | 04:16 AM
That's a strange question to ask you. The obvious question is 'Standard or R Performance (Brembo)' brakes. I'm also wondering exactly what he means by 'clips'........
This is the Standard Brake:
The Anti Rattle Spring (item 7) is listed in the Parts Catalogue as a Housing Clip but a.f.a.i.k. there is only one size.
The Brembo pads are held on Pins (item 6):
These are secured by Clips (item 1):
There could be two different sizes of these Clips available.
Attached Thumbnails Brake pad ?-rear-brake-standard.jpg   Brake pad ?-rear-brake-brembo.jpg
Old Apr 17, 2013 | 09:12 AM
Cyqb XK8's Avatar
Being a XK8 it is part number D688 in the aftermarket.
I am a brake manufacturer in Canada:-)
Old Apr 17, 2013 | 02:06 PM
randyb's Avatar
Attachment 39991
Graham,
When I looked at Rockauto.com, some pads said small clip, one said large and the rest did not mention the clip, so I do not know why they asked.
Old Apr 17, 2013 | 02:25 PM
Jag#4's Avatar
Originally Posted by randyb
Graham,
I put on Rock Auto pads just 30 days ago for my '01 XK8. You want the standard pads, NOT the ones that say "with performance kit". I ordered that set thinking it included all the hardware, but it is the set for the Brembo brakes. Unless you have upgraded brakes on your XK8, you'll need the set without the performance kit.
The pictures actually show which ones you want very well.
Old Apr 17, 2013 | 02:27 PM
randyb's Avatar
Thank YOU!!!
Old Apr 17, 2013 | 02:50 PM
......... You want the standard pads, NOT the ones that say "with performance kit". I ordered that set thinking it included all the hardware, but it is the set for the Brembo brakes. Unless you have upgraded brakes on your XK8, you'll need the set without the performance kit........
Jaguar still persist with the confusing 'R Performance' badging. The rear caliper on mine has this logo:
Not a mention of 'Brembo' in the sales brochure either. Despite the fact everyone calls them 'Brembo'!
H20boy
Dec 24, 2024 03:23 PM
perezal
Dec 29, 2015 08:48 PM
ahunt4
Sep 19, 2015 09:49 AM
1964Daimler
Sep 9, 2015 11:28 AM
JagLove86
Sep 6, 2015 10:36 PM
