Brake pads
Old May 1, 2024 | 12:08 PM
66RBS's Avatar
Default Brake pads
re 2003 XK8. 81000 miles
I have a work order from prior owner front pads replaced at 50K. No info on rear pads
Front pads look good maybe 1/4" but not able to view rear pads clearly
Is there an indicator when rear pads should be replaced?
Randy
Old May 1, 2024 | 01:37 PM
Jon89's Avatar
No indicator wear-bar chirping noise that I am aware of. Best thing to do is pull the rear wheels and take a good look through the viewing slots in the calipers.. A small flashlight helps....
Old May 1, 2024 | 04:09 PM
zray's Avatar
I don’t let them get less than 5 mm. Which is about 0.2 inch
By the way, the ebc redstuff pads I use on multiple vehicles are a night and day improvement over the OEM pads. I recommend them to anyone wanting an upgrade in stopping power over their current set-up.
They will stop the car quicker than the OEM pads, leave very little brake dust, and are very easy on the rotors. Which was a surprise for me considering their increased friction coefficient.
Z
Old May 1, 2024 | 10:27 PM
JACKP's Avatar
Z
Zray, is ebc redstuff the name of your brake pads. I would like to change the ones on mine as the keep the front wheels completely filthy.
Jack
Old May 2, 2024 | 12:50 AM
zray's Avatar
Jack
ebc is the manufacturer. They are a British company. They make many different pad compounds. The “redstuff”
compound is the one I prefer for my driving needs. Which are “spirited, but far from racing”.
Amazon has them, as well as vendors like Summitt.
the front pads for my 2002 XKR are this ebc part number:
Front: EBC Brakes DP3689/2C Redstuff Ceramic Low Dust Brake Pad
Rears: EBC Brakes DP31198C Redstuff Ceramic Low Dust Brake Pad
i have the standard ATE brakes, not the Brembo’s.
Amazon:
https://a.co/d/74y0vHN
Old May 2, 2024 | 06:25 AM
JACKP's Avatar
Thanks for the information zray
Jack
Old May 2, 2024 | 11:42 AM
giandanielxk8's Avatar
Z
My car has the OE Brembo system and I had the Redstuff. I was initially happy with them but on more spirited driving down canyon roads, they were not enough. I encountered lots of brake fade. Once the pad had worn, I replaced the Reds with EBC's BlueStuff pad. They were a little harder to break in than the RedStuff, but they have a stronger initial bite and they brake harder overall. These can also withstand abuse much better, having a broader operating temperature than the RedStuff. They are meant for occasional track days and sporty street use, given their higher friction coefficient over the Reds. They DO dust up more than the Reds and they do make more noise, especially during the break-in period. These give me much more confidence when stopping, so the initial noise and the dusting is a worthy compromise in my book. I also went ahead and flushed my brake fluid and filled it with ATE type 200 DOT 4 racing brake fluid.
This new setup pretty much made me forget wanting to add an electronic vacuum pump to the system.
Old May 2, 2024 | 08:42 PM
zray's Avatar
I think you found out the beauty of the ebc lineup. They seem to have a pad for every type of driving.
Have you had the new pads on long enough to know how hard they are on the rotors ?
Z
Old May 2, 2024 | 09:46 PM
Z
I've had them for about 8 months. I still haven't noticed the wear on the rotors.
Old May 2, 2024 | 10:45 PM
zray's Avatar
I’m on my 2nd set of ebc redstuff pads in front. The rotors were put on with the first set, and still measure the same as new. And no grooving or hot spots either. I was sure I’d wear out the rotors as the same rate as the pads. Nicely surprised with the longevity of both pads and rotors.
my first set of pads lasted 58,000 miles. I change them when the material thickness is down to about 5 or 6 mm.
Z
ugotmale
Jul 3, 2022 01:01 PM
OldCoot
Apr 23, 2022 09:38 PM
jagtoes
Mar 20, 2020 01:54 PM
Sonspit
Jul 11, 2014 08:52 AM
FloridaJag
May 28, 2009 07:26 AM
