Brakes ???
And the answer is - only if the discs are worn below the wear limit, or are badly scored, or are distorted. From the mileage you state, I would expect one of these to be applicable by now.
Other thing I forgot was corrosion. Ventilated discs have passages through the middle and corrosion in these can cause the disc to lose strength. It has happened that the inner face has detached itself under braking due to corrosion, but this is a very rare event, and when brake (and most other) servicing has generally been completely neglected.
By the way, discs should never be skimmed; it usually takes the disc below the wear limit.
Some people expect things to last forever without attention, maintenance, or anything !!
2003 XK8 75k .. brakes work fine, but the rotors are mabe .05 worn and a little glazey. Svc record shows rotors swapped at least once, and a couple of pad swaps. No question about renewing all, and just wondering your opinion regarding brakeperformance ... ic performance slotted and cross-drilled and electro-black zink for 270 a pair for front, 133 for rears .. lifetime warranty, and 60 and 57 respectively for pads. Looks good to me, with lifetime warranty and directly from usa mfg .. free shipping doesn't hurt either. I have no commercial interest or connection with above named entity .. just seeking comments on other members experience regarding brake parts. I tagged this onto h2oboy's post .. cause with over 4k posts and a mod .. hope to get some knowledgible advice. Pads .. metalic-ceramic??? Gonna change out frnt brgs as long as i'm in there.
attaboy, this is an issue that doesn't have one correct answer to your question, there are several disc manufacturers and pad types that will often have many recommendations. I can only recommend what I know from experience, as will the other jag owners.
As long as you select rotors and pads that gets a few good thumbs up, you'll be just fine. My Brembo-Akebono Euro combination has been going strong for 56k miles now.
The one aspect that I will suggest with more fervor is the selection of brake pads. I've had the OEMs, the EBC reds, and now the Akebono Euro Ceramics. Of all the three, the Akebonos have the least amount of dust, almost nill. That was important to me, along with similar performance of the OEMs. Now, others have stated that the EBC reds have better stopping ability, I didn't try them out as hard before replacing them and don't have the driving style to warrant their need.
Good luck w/ your project!
Just want something that works without compromise. I'm not gonna be testing the 155mph chip limit, but even a babydeer or wild turkey would mess up my grill .. LOL
Stopping ability, is my primary criteria .. God knows ... the XK8 has to go-fast part dialed in :-)
Look up this recent thread
front brakes and another one where Gus replied that he acquired an impact wrench to get the carrier bolts off. I have done mine without, and nearly busted my gut getting the bolts loose. Either get the biggest breaker bar you can fit on it, or try the impact wrench method. Assuming that is the problem you are having trying to get the rotors off.
front brakes and another one where Gus replied that he acquired an impact wrench to get the carrier bolts off. I have done mine without, and nearly busted my gut getting the bolts loose. Either get the biggest breaker bar you can fit on it, or try the impact wrench method. Assuming that is the problem you are having trying to get the rotors off.On the bright side .. at least they are not using Whitworth threads .. LOL ... gotta '57 BSA 650 ... whuddah pain .. no wiki back then ehh :-)
Speaking for myself .. having that "ohh sh*t" moment when, even driving conservatively (I haven't had a ticket since 1980) the whole friggen freeway has become instantly almost frozen .. and you don't trust your brakes and pull over .. sorta of .. into a non-traffic-lane to the left or right.
A super-premium brake job will cost you less than a years insurance on one of these Kitty's if you spec your own parts and DIY, or using a local trustworthy competant mechanic. I figure ... if you're gonna drive a car that cost over $70k new .. going cheap on brake parts, is like filling up with regular. jmho
This thread is about reccommendations, and I sincerely appreciate your input. As to the rotors, if I can buy direct from a US manufacturer that gives a lifetime warranty, electro-zink corrosion protection, free shippng, F $270.51 a pair, R $132.85 a pair ... the "Italia" stuff ... just doesn't make my boat float for slotted drilled non-plated rotors.
At the very least ... it's not a competitive price, and if it's actually made in Italy .. what is the warranty policy and how do you get warranty service? This is not a rant .. but we used to make "stuff" in this .. our country. I luv Italia .. and chinese and mexican too .. in food .. LOL
Summary is a bit OT ... my first tractor here .. is a 1952 Ford 8n .. last year of production, 472,000 made. Made here. For equally comparable products, I would pay a 20% premium for US made rotors ... cause .. as my old boss at Westinghouse said 35 years ago .. we gotta put parts on the floor. If Ford hadn't goosed Jag .. we wouldn't be aluvin' these incredible vehicles.
Then you'll probably want EBC for rotors and either EBC or Hawk HPS for pads. EBC (UK/USA), Hawk (USA).
Brembo is what I am currently using with Performance Friction pads which aren't any cleaner than OEM but stop great and dead quiet. I would have gotten the Hawk HPS but they weren't available for the XK8 the last time I checked and apparently now they are. I had hawks on my mustang and loved them, they had the least dust of any I tried and stopped awesome.
Had ceramics prior to that and I didn't like them at all. Were'nt very clean and sounded like a school bus stopping, very disapointed. They weren't the akebono's though, forgot which one they were and swore never to use ceramics again.
Brembo by the way has production facilities in 12 countries so I'll have to check my box to see where they were actually manucatured.
Don't mind cleaning my wheels, I like stopping when I need to!
Jaguar have spent a little time on disk brake development. I would go with the stock Jurid and or Mintex pads and stock rotors. No compromises to keep those shiny wheels clean!
Aren't we supposed to drive these cars?
We are in good company with our toasty wheels.
The key value in disc replacement is "Minimum Thickness". This is normally specified by the brake manufacturers and also on the technical data from Jaguar. Even if not scored if the actual thickness is below the minimum, the discs should be replaced. If within tolerance but badly scored, or warped, then replace also, otherwise retain. Discs should last longer than a single set of pads, but may not do so.
xjrjag
Sep 24, 2015 10:08 PM
