brembo brake calipers
Old Jul 28, 2013 | 09:43 AM
gregjen's Avatar
Default brembo brake calipers
I've been told that the steel plate which holds the brake pad has risen up due to corrosion underneath it. Where is the best place to rectify this problem.....I live in Manchester
Old Jul 28, 2013 | 01:33 PM
Is that the steel plates top and bottom (arrowed in red) that the pad backing plate slides on?
As you can see from the photo, the top left of this caliper is showing corrosion but there's no distortion of the steel plate. Just how bad are yours?
Old Jul 30, 2013 | 02:47 AM
gregjen's Avatar
Hi,
Yes, there are 2 steel plates above and below the pad. The corrosion under the plates is lifting the plate and causing the pad to stick, resulting in a loud noise on braking
Old Jul 30, 2013 | 03:25 AM
I didn't take too much notice of the plates on mine other than cleaning the calipers before fitting new discs and pads. Are the plates riveted on or secured with set screws?
Old Jul 30, 2013 | 05:23 AM
gregjen's Avatar
they are screwed on....unfortunately, the screw is tiny and gets corroded, so is a nightmare to remove...often needing drilling out. This is why I'm looking for a brake expert (near manchester england)
Old Jul 30, 2013 | 05:53 AM
Try Classic Brakes at Chelford in Cheshire.
www.classicbrake.co.uk Home
It's a while since I've needed calipers rebuilt but he did a superb job on my Aston Martin DB5 brakes and I've heard good reports about him since then.
wvanepps
Oct 4, 2015 10:01 AM
GT-Z
Sep 23, 2015 03:50 PM
Jagman28
Sep 14, 2015 01:37 PM
Richard_gib
Sep 11, 2015 08:02 PM
metalmarty
Sep 11, 2015 07:05 AM
