Brembo upgrade on 2001 XKR Coupe
Old Oct 23, 2009 | 11:21 AM
SteveM's Avatar
I had the same issue when I upgraded to Brembos on my XJR. I used 20 mm spacers to clear my stock wheels. All you probably need is 20mm per side. There is no issues with turning or handling. Of course the perfect scenerio would be to have wheels that fit fine without spacer but the spacers shouldn't have a negative affect.
You don't use longer studs with these spacers. The spacer bolts on to the hub with the included nuts and then you bolt the wheel onto studs that are fixed into the spacer with your lug nuts.
If you want to go this route, I have two pairs of H&R 20mm spacers for sale. One pair is brand new and unused and the other pair has under 1000 miles on them. They clear the front Brembos by at least 3/8 inch and give the car a perfect stance. I could sell them for $300 shipped.
Here's how they look like to give you an idea how they mount:
toronadomike
Jan 22, 2026 10:13 PM
Beardy
Sep 18, 2015 10:00 AM
tberg
Sep 17, 2015 10:43 PM
Skeeter
Sep 17, 2015 08:15 PM
skadmiri1
Sep 9, 2015 11:27 AM
