Broken off abs module li front wheel how to fix it
Old Sep 10, 2013 | 02:01 PM
Gertveer's Avatar
Question Broken off abs module li front wheel how to fix it
My rh front wheel abs sensor bolt snaped off can some help me and tell me how to repair that?
Gert
Old Sep 10, 2013 | 07:25 PM
Welcome to the forum Gertveer,
The top of this bolt (arrowed in red) has snapped off?
If you can remove the sensor, use a Stud Extractor to remove the broken bolt:
To use these, select one smaller than the broken bolt. Drill a hole into the remaining bolt. The extractor then screws in anti-clockwise and unscrews the broken bolt.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST section and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Attached Thumbnails Broken off abs module li front wheel how to fix it-ux_a08092900ux0077_ux_c.jpg
Old Sep 10, 2013 | 08:21 PM
plums's Avatar
If there is enough of a stub left, there are newer stud extractors that are much like a socket with locking cams that do not require drilling.
Preparation should include soaking the joint with good penetrating oil and hammering on the end of the broken bolt to aid in breaking the corrosion.
Visegrips/Molegrips sometimes work well if they are put on *very* tight.
Old Sep 10, 2013 | 08:48 PM
Bob OB's Avatar
Cool Extractions
Removing a broken bolt is a learned skill. if you've never done it before, it may be best to have a professional mechanic do it. You will agree with me after the extractor breaks off inside the bolt. Your call...
Old Sep 11, 2013 | 09:03 AM
mike66's Avatar
If it's frozen enough to shear the head of the bolt off, it's going to be tough getting the bolt out with an extractor. However, if you have time, why not try-it's alredy broken. Lots of penetrating oil, hammering, possibly heat, anything to help loosen it. And yeah if the extractor doesn't do it with reasonable force, back off before that snaps off as well. Go to a larger drill bit and extractor size. Good luck!
BrentGardner
29
Dec 16, 2024 12:13 AM
Jimscriv
Nov 4, 2015 02:18 PM
Fraser Mitchell
Oct 1, 2015 04:06 AM
Pristine97XK8Convertible
Sep 29, 2015 02:43 AM
Bernie Posadas
Sep 3, 2015 08:06 PM
