Bulb Fail Rear
Old Mar 26, 2021 | 12:16 PM
Riley VanSuetendael's Avatar
Default Bulb Fail Rear
I recently added LED bulbs to my rear tail lights on my 97 XK8. I got a warning light on the dashboard. I assumed that it was because the LEDs draw so much less power than the original bulbs, so I wired in some resistors. That took care of the error message for my running lights, but I still get a warning message whenever the brake lights turn on. Adding lots of resistance hasn't fixed the issue at all, so I suspect there is some other way the error message is flashing on. Anyone have any advice?
Riley
Old Mar 26, 2021 | 02:17 PM
ccfulton's Avatar
If you put the conventional bulbs back, does the error go away?
If yes, then still not enough resistors.
Old Mar 26, 2021 | 09:37 PM
bcprice36's Avatar
Mr. VanSuetendael:
As Charley said above: You will need to add more resistors to the Brake Lights.....I'm not sure how the 1997 Tail lights are wired, so you will need to get the Wiring Diagram for that year and determine which wires go to the Brake Lights...add a resistor to each one....and Hope!
Billy Clyde @ Cinco Ranch
Old Mar 29, 2021 | 02:36 PM
Ledmi's Avatar
Default Brake Led light versus Transmission faulty
Riley
Be careful, I did the same bulb replacement before and even with resistors the warning lights went Off. I was happy until I had a faulty transmission. The gears were not shifting I had to use it manually. After removing the LED and resistors, it came back perfect. Since then I stay away from LED. The computer is very sensitive.
Michel
thom4782
Dec 25, 2018 11:27 PM
vincent661983
Sep 9, 2018 09:28 AM
bcprice36
Sep 5, 2017 12:52 PM
morrisonjagxj8
Sep 20, 2009 09:17 PM
