cabin filter
Old May 26, 2014 | 12:42 PM
magnum454's Avatar
Question cabin filter
Is there a cabin filter in a 2000XK8 conv. and if so where is it?
Old May 26, 2014 | 12:47 PM
ccfulton's Avatar
It was an optional item and very few cars had it fitted.
The filter would be located under the cowl cover panel toward the right hand side. To get at it, you start by removing the wiper arms...
Old May 26, 2014 | 05:08 PM
franksm's Avatar
Remove the wipers (you'll need a little tool to "pop" the wipers off their spindle), remove the plastic plenum panel, and you'll see where the filter can go.
This might help:
Attached Thumbnails cabin filter-img_1502_zps4baac776.jpg   cabin filter-img_1501_zpsa363620e.jpg
Old May 26, 2014 | 05:17 PM
Jandreu's Avatar
Nice go Jaguar to make it easy and accessible .....
Old May 26, 2014 | 05:22 PM
test point's Avatar
Not much of a problem since just about none of the cars sent to the US had the filter housing installed but lots of folks have bought the filters with good intentions.
Old May 27, 2014 | 06:57 AM
Jon89's Avatar
No point to fitting a cabin filter in a ragtop, you know....
Old May 27, 2014 | 07:16 AM
Not too sure why they call them "pollen filters" on the XK8/XKR.
My XK8's didn't have them but the one on my XK (now renamed "cabin filter" on the later model) trapped a lot of black industrial particulates in only a few months.
Old May 27, 2014 | 09:23 AM
magnum454's Avatar
good point!
Old May 27, 2014 | 03:06 PM
Andy Cox's Avatar
Is there any easy way of telling if it is fitted or not. I don't particularly want to pull all that lot apart if there's no filter there.
Andy
Old May 27, 2014 | 03:46 PM
test point's Avatar
There is not really any way to verify the filter housing except removing the plenum panel. A build sheet available from a dealer will tell you if it left the factory with one but the housing has a part number and could have been installed later . . . or not.
Old May 27, 2014 | 05:28 PM
Originally Posted by test point
There is not really any way to verify the filter housing except removing the plenum panel. . . .
+1
a.f.a.i.k. it's impossible to see the filter housing through the panel.
Knowing what you're looking for can help. Here's the extract from the Parts Catalogue showing the housing and filter:
From previous threads about the pollen filter, those who have one fitted have often found it does more the restrict air flow to the AC than provide effective filtration as it can easily get blocked.
Old Jul 30, 2016 | 09:16 PM
cyber3d's Avatar
Default Bump
WTF. All that trouble only to find an empty hole.
And of course I now have two useless new filters!
Will have to make my own. Anyone have a pic of what the filter holder should look like? Maybe the dimensions between the mounting holes too?
Oy.
Old Jul 31, 2016 | 11:48 AM
Norm 427's Avatar
I feel your pain.
Yesterday I bought a cabin filter and I just spent a lot of time this AM pulling stuff apart only to find out this 2003 XK8 doesn't have one. Grrr.
Old Aug 3, 2016 | 09:06 AM
fmertz's Avatar
AFAIK, the whole "filter" is really a paper element and a plastic template the filter fits into. The template is secured to the car with a couple of paint-drilling screws. It is all listed in the parts catalog, a couple of posts above. I ordered the template from the dealer a number of months ago (have not installed it, yet). The whole thing was fairly inexpensive, as I suspect Jaguar is sitting on a mountain of those. One more thing, the RHD and LHD cars have a separate plastic template, probably mirror image, with separate part#.
Best of luck, keep us posted.
Old Aug 3, 2016 | 11:40 AM
cyber3d's Avatar
Hey fmertz, can you post a few pics of the darn thing? From the top, from the back, from the side? Would really appreciate it. And which dealer did you purchase from?
Old Aug 3, 2016 | 11:45 AM
fmertz's Avatar
It's item#4 in the picture post above. The part# is MJD6865AA. i bought mine from a local dealer, based on the part#. Took a couple of days to come in...
Old Aug 3, 2016 | 12:07 PM
cyber3d's Avatar
Do you know what that item 6 is? Do I need to get that too?
Old Aug 3, 2016 | 12:18 PM
fmertz's Avatar
Not 100% sure, but I did not order it. My sense is that it is already in the car, at the very top of the air box.
There is a great how-to in this post: retro-fitting-cabin-pollen-filter-57668/
Old Mar 20, 2021 | 05:30 PM
STLTHMSTA's Avatar
Well, for criminy sakes!! I fell for the April Fools joke of the cabin filter change. Darn it! I don't have one. %$#&@*&& Anyone need a free air filter? TM
Old Mar 21, 2021 | 05:24 PM
Timeisrelative's Avatar
Mine uses one lol
