Can cylinder misfiring also throw code for nearby cylinder?
2002 XK8. Had misfires on 7 & 8. Switched coil from 8 to 5 and 7 to 6. Now just pending code for misfire on 5. I think I’ve heard yes to question above. Thoughts?
Probably just order two in any event to have an extra around. I’m not one of those guys who believes in changing every coil when one goes bad.
Since all your misfires are on bank 2, one way to tell who could be at fault is to mark all 8 coils with a marker for their cylinder ID and swap them from one bank to another, clear the codes and test drive it. If the misfire(s) move with the coil swap, you’ll have your answer (hopefully). I know these cars can be finicky at times though.
leaddog11
Mar 17, 2023 11:33 AM
Willyb
Dec 17, 2013 03:51 PM
