Can cylinder misfiring also throw code for nearby cylinder?
Old Jan 22, 2025 | 02:32 PM
pcolapacker's Avatar
Default Can cylinder misfiring also throw code for nearby cylinder?
2002 XK8. Had misfires on 7 & 8. Switched coil from 8 to 5 and 7 to 6. Now just pending code for misfire on 5. I think I’ve heard yes to question above. Thoughts?
Probably just order two in any event to have an extra around. I’m not one of those guys who believes in changing every coil when one goes bad.
Old Jan 22, 2025 | 03:01 PM
JagV8's Avatar
Maybe/probably - it's hard for it to detect and diagnose misfires.
If you swap, keep the old ones in case the new turn out worse...
Old Jan 25, 2025 | 02:32 AM
Pistnbroke's Avatar
before you fit blow out plug recess with compressed air ....my misfires caused by water around the plug.
Old Jan 25, 2025 | 02:47 AM
JagV8's Avatar
Check for oil there, too.
Old Jan 25, 2025 | 03:56 AM
dibbit's Avatar
It uses the crankshaft position sensor to calculate crankshaft acceleration and therefore detect a misfire and which one it was. That should be pretty accurate.
Old Jan 25, 2025 | 04:47 AM
Addicted2boost's Avatar
Since all your misfires are on bank 2, one way to tell who could be at fault is to mark all 8 coils with a marker for their cylinder ID and swap them from one bank to another, clear the codes and test drive it. If the misfire(s) move with the coil swap, you’ll have your answer (hopefully). I know these cars can be finicky at times though.
leaddog11
Mar 17, 2023 11:33 AM
Razkid
Mar 8, 2014 03:26 PM
Willyb
Dec 17, 2013 03:51 PM
dennisw
Jan 25, 2013 06:23 AM
carter
Dec 22, 2008 06:46 PM
