Car stalls when put in gear
Old Dec 12, 2017 | 12:04 PM
Mugzyscar's Avatar
Exclamation stalling out when put in gear
97 XK8 car starts fine. Shifter allows gear to be selected but then lurches hard and engine kills. Drove car to work and had no problem. Parked in parking garage on slight incline. Came out of work and had above issue. Open to suggestions not sure if I can get tow truck into garage hope I can get help to get it moving again. Thanks
Old Dec 12, 2017 | 04:39 PM
pacobeagle's Avatar
Fuel level?
Old Dec 12, 2017 | 07:20 PM
Anthony8858's Avatar
Originally Posted by Mugzyscar
help. Car starts and gear shift allows gear to be selected but kills when put into reverse or drive options. Idles while In Park or neutral
don t know if it matters but 8 hrs before car drove fine. Took it to work and parked in car garage and know won’t go into gear. Not sure but car is also on slight incline in garage. It is an 97 XK8 convertible. Help me get it home thanks
This happened to me last year....
I changed 2 things:
The fuel cap and the fuel filter.
One or the other was the culprit... Price was so cheap, it was worth changing both.
never happened again.
Old Dec 12, 2017 | 08:07 PM
Flipr78's Avatar
i would be testing the fuel pump......
Old Dec 12, 2017 | 09:11 PM
Mugzyscar's Avatar
It idles and revs. Then when put in gear in lurches and kills
Old Dec 12, 2017 | 09:13 PM
Thats much different than stalling when you out in gear..
I'll wait for the experts to chime in, but Im gonna guess it has something to do with the throttle body sensor.
Old Dec 13, 2017 | 06:48 AM
JagV8's Avatar
Maybe an air leak as a hose flexes.
Old Dec 13, 2017 | 02:31 PM
harryxtype's Avatar
I had a similar problem with my x type, The engine fired up and idled but there was no power when I put it in drive, it turned out that the battery was getting old and weak. A new battery solved it. Strange but true
Old Dec 15, 2017 | 10:39 AM
Got a Jaguar Jones's Avatar
Perhaps the lock up solenoid on the torque converter is bad, and has direct drive when put into gear. IF IT IS SAFE, start the engine and without braking, put it in gear and accelerate slightly to see if the car moves. something like starting a manual shift car in gear without the clutch being engaged.
hooter
Mar 5, 2017 07:07 AM
newguy12
Mar 11, 2013 08:01 PM
Peter Duffy
Nov 27, 2011 06:00 AM
jagxkrtoofast
Sep 13, 2010 11:40 AM
