Car went crazy
Old Dec 15, 2018 | 08:42 AM
larueb's Avatar
Default Car went crazy
Need help big time, stranded.
heavy rain last night. This morning car will not start. Woosh sound from dash, cant put in neutral, windows work then dont. Tried to jump start, no difference. Acts like it kind of died. At hotel so limited resources.
Old Dec 15, 2018 | 08:45 AM
JimmyL's Avatar
Does the engine crank over ? Check/clean the battery connections and grounds if you can. Do a hard reset.
Old Dec 15, 2018 | 09:22 AM
CorStevens's Avatar
when you do the hard reset i find that this works well. disconnect the battery, connect positive to ground solidly, turn ignition to run going all the way as if engaging the starter, leave the key as if it was running. 30 minutes later, turn to off and remove the key making sure that the little door in the key slot closes. during the half hour wait, load test or at least check the voltage of the battery, replace if necessary. clean connections, reconnect positive first then ground. turn ignition to on, wait until dash lights check completes, crank until start but not more than ten seconds. the engine will run fast and then settle, let it warm up and see if you can reset the windows.
Old Dec 15, 2018 | 09:31 AM
CorStevens's Avatar
note that if rain did this, you might want to check the compartment where the computer resides to see if it is flooding due to drains being plugged. there are two, the scuttle from the cowl to keep water from getting in and the lower front corner of the compartment to drain out anything that might get in there.
if the car runs at all but not well, set the parking brake, shift to drive (you must push the brake to exit park) then back to neutral and leave it there. it will make it easier to load the car onto a flat bed if it needs to be transported for repair. you can turn off the engine with the car in neutral.
Old Dec 15, 2018 | 10:20 AM
larueb's Avatar
Resolved!!! Thanks to all. Seems like my battery went bad despite what Advanced Auto said. I have 9 instead of 900 cranking amps!!
Sure died in a hurry!
Old Dec 15, 2018 | 10:36 AM
zray's Avatar
The NAPA AGM battery is a good choice.
Z
Old Dec 15, 2018 | 12:50 PM
ken qv's Avatar
Where are you. I am in Tampa with tools.
Old Dec 16, 2018 | 04:29 AM
frankc's Avatar
Ignore the people who say your battery is ok, as you found out. A dying battery can give off all sorts of weird symptoms. Glad you sorted it!
User 070620
Jan 29, 2013 03:45 AM
Bigvettefreak
May 26, 2012 09:56 AM
iownme
Sep 13, 2011 03:59 AM
jnporcello
Apr 29, 2010 10:49 AM
